TCL within CiscoWorks
Mehdi Talei
Hello all,
I have written the following script which shuts down the "down" interfaces on Catalyst 2960. When I copy and paste the script via SSH, it works fine without any error message, but when I execute it via CiscoWorks (RME 4.3.1) the job fails with the following error message:
tclsh
Switch(tcl)#
for {set x 0} {$x<24} {incr x} {
missing  close-brace
Switch(tcl)#
set etat [string range [lrange [exec sh ip int  brief | i FastEthernet0/$x] 4 4] 0 4 ]
can't read "x": no such variable
Switch(tcl)#
if { [string equal $etat "down"] } {
missing close-brace
Switch(tcl)#
puts [ios_config "Interface FastEthernet0/$x"  "shut"]
Switch(tcl)#
invalid  command name "}"
% Invalid input detected at '^' marker.
Switch(tcl)#
I am wondering why I get "missing close-brace" error message!
Any help is appreciated.
Mehdi
Joe Clarke
When you type in the script line-by-line like this, you get intermediate prompts requesting additional block data.  LMS cannot programmatically handle those prompts.  Instead, try converting your script to a single line:
for {set x 0} {$x<24} {incr x} { set etat [string range [lrange [exec sh ip int  brief | i FastEthernet0/$x] 4 4] 0 4 ] ; if { [string equal $etat "down"] } { puts [ios_config "Interface FastEthernet0/$x"  "shut"] } }
Joe Clarke
Thank a lot Joseph for your excellent hint. On a single line works perfectly.
