Teams QoS configuration
ergamusai
I need to configure QoS to prioritize Teams traffic. Is this config doing what I need to do
policy-map PM_MS_TEAMS_OUT
class CM_MS_TEAMS_AUDIO
priority level 1
police rate percent 10
class CM_MS_TEAMS_VIDEO
priority level 2
police rate percent 20
class CM_MS_TEAMS_SHARING
bandwidth remaining percent 15
queue-buffers ratio 10
class class-default
bandwidth remaining percent 35
queue-buffers ratio 25
policy-map PM_MS_TEAMS_QOS_SHAPER_OUT
class class-default
shape average percent 90
service-policy PM_MS_TEAMS_OUT
In that case, you don't need the shaper.  As the interface queues, you can manage dequeuing prioritization.
Something you might check is if the interface has a large tx-ring.  Only when FIFO queue overflows into the policy queues do you get their dequeuing sequence.
I.e., you may want to reduce the size of the tx-ring.
7 Replies 7
Joseph W. Doherty
Possibly, logically.  Insufficient information for optimal non-PQ bandwidth and/or buffer ration allocations.
Also shaper and hierarchal policy needed?  90% is a surprising number for a shaper.  At that level, why isn't 100% available.
I am not sure if the hierarchies policy is needed. I don't understand the last part very well, which is why I'm asking. My goal is prioritize teams traffic during congestions
If you need to shape, your basic structure is fine.
If you don't need to shape, your child policy would be your only policy.
Thank you, seeing that we are maximizing our circuit, shaping should help. But from what I'm understanding correctly the shape average value should be 100.
Shaping is used to allow you to manage a downstream bottleneck that you otherwise cannot manage.
For example, if a WAN provider connects with you using fast Ethernet but tells you they won't allow more than 50 Mbps, shaping would allow you to manage that 50 Mbps.
Yours is a similar situation?
Ah, I see. I am not in the same situation. My provider facing interface is 10g and my bw is 10g. This has been very helpful. Appreciate your help and quick replies
