Tools for Network design
calebcastillo
Hi, I´ve been working as a network designer for the past six months and I´m looking for tools that help me make better assessments about the flow of the network and the type of traffic.
I´ve found tools but some of them are expensive. I would like to know what type of tools do you guys use?
luis_cordova
Hi @calebcastillo
I always thought PRTG is a good tool to start monitoring.
The free version allows you to have 100 sensors.
Obviously, if you need more, you should opt for the paid verison.
https://www.paessler.com/free_network_monitor
7 Replies 7
luis_cordova
Hi @calebcastillo
Hi Luis,
Thanks so much for your input I will give it a try for sure.
etoromol
Hello Caleb,
During my experience working in network environments, I noticed there isn't any "default" app to elaborate topology designs. Having said that, I found Microsoft Visio as one of the most used apps by network engineers to maintain their network diagrams.
There is an open-source app called Dia which I use for small projects. It is very stable and you can download the official Cisco Icon pack and installed on it. I leave you the link for your own review:
http://dia-installer.de
Eduardo
Hi Eduardo,
I use Viso, but never heard of Dia, good to know thanks for your answer.
balaji.bandi
I use Visio and cisco stencils they are much better and easy.
BB
Deepak Kumar
I am using Microsoft Visio and cisco stencils. Really, I tried a few tools but I like Visio.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
for network assesments and mapping the actual topology I use Network notepad, and for monitoring a free one that could work is Cacti. You can download de suse iso that includes it and its already installed.
