02-15-2006 01:40 PM
Okay, I started out with installing Common Services 3.0 on a Win2003 standard box that's patched w/ sp1. The version of the software I have is a package update, Prod CWLMS-2.5-SR-K9. I installed CS 3.0 and the december update. So far, I have been unable to access the web interface of Ciscoworks and, if I try to run pdshow, it hangs.
Off to a bad start here .. any help in which direction to go would be appreciated.
02-15-2006 03:34 PM
What's the cpu utilization on the server like?
How much memory do you have installed?
02-15-2006 05:28 PM
CPU utilization is nill. 4 gigs of memory.
I just realized I installed Cworks with Terminal Services running. Is this something that needs to be disabled when installing Cworks or it needs to be turned off all the time when Cworks is installed on the machine?
02-15-2006 06:30 PM
Terminal Services needs to be disabled during installation. It can be enabled afterwards to access the server.
02-16-2006 05:25 AM
Thanks. I'll do a re-install and give it a try with it disabled.
02-16-2006 09:50 AM
Didn't work. I re-installed Ciscoworks Common Services 3.0 with Terminal Services disabled but the server still fails to start up. To be more specific, I am seeing the following error in the event log:
"The Ciscoworks Tomcat Servlet Engine service terminated unexpectedly. It has done this 1 time."
Whenever I try to re-enable the servlet, the same error is produced.
Am I missing something else here? I disabled remote desktop and the terminal services.
02-16-2006 10:08 AM
If you look at the Windows Services, you should see CiscoWorks Tomcat Servlet Engine listed.
What is its Startup Type (Manual or Automatic)?
Also, what user were you logged in as when you performed the installation (local or domain)?
02-16-2006 11:16 AM
The startup type is manual.
I was logged in as Administator, assuming local. Basically did a fresh install of the OS, created the Administrator account, and did the install afterwards.
02-16-2006 11:22 AM
It all looks good. Not sure why this is happening. Log file analysis will be required by TAC.
02-16-2006 03:42 PM
I'll try posting to the forum in general to see if anyone else has had the same problem. Going to be a couple of weeks before the SAS contract is renewed.
