types of cisco IOS
chasm_Ger
i have to upgrade our cisco 2811 router, because of a buggy IOS version - 12.4(3a) with advanced security feature.
I'm not involved with handling IOS versions. What are the important differences between General Deployment (GD), Limited Deployment (LD) and Early Deployment (ED). Is the T behind the version number somewhat like - not stable - testing?
I plan to update from
c2800nm-advsecurityk9-mz.124-3a.bin
to
c2800nm-advsecurityk9-mz.124-8.bin
Except nvi configuration - for natting with replacing the original source ip from outside with the routers internal ip - there is no special configuration on the router so far.
VPN and HSRP will follow later...
So the "big" upgrade jump from 12.4 (3a) to 12.4 (8) should be no problem? Or is this upgrade jump not as big as I think?
desai.jaideep
Level 5
Level 5
This is what cisco defines ED, GD and LD.
Software releases that provide new features and new platform support in addition to bug fixes.
A Major Release of Cisco IOS or a Release Train of CatOS software is said to be in the "Limited Deployment" phase of its lifecycle during the period between Early Deployment (ED) and the General Deployment (GD) milestone. No new features or new platform support is added in this phase, only bug fixes.
Date at which this software release reached the "General Deployment" milestone in its lifecycle. A Major Release of Cisco IOS or a Release Train of CatOS software reaches the "General Deployment" milestone when Cisco feels it is suitable for deployment anywhere in customer networks where the features and functionality of the release are required. An example of a Cisco IOS Major Release which has reached GD is:12.2. An example of a CatOS Release Train that has reached GD is 7.x. Criteria for reaching the "General Deployment" milestone are based on, but not limited to, customer feedback surveys from production and test networks using the releases, CE bug reports, and reported field experience.
As per your "jump" I dont believe that there is anything that you will gain.
In 3a ver. there are unique features such as
"FHRP - Enhanced Object Tracking of IP SLAs
Firewall Intrusion Detection (IDS) Signature Enhancements
Reverse Route Injection "
and in 8 ver is
"Embedded Event Manager (EEM) 1.0
PPTP with MPPE ".
....rest all the features are same.
Pls rate the post if it had helped.
JD
desai.jaideep
Level 5
Level 5
and in 8 ver is
PPTP with MPPE ".
JD
