11-11-2021 06:05 AM
Hello All
We have UCS-E160S-M3/K9 installed in ISR 4331 Routers. Can you help me about how can i find hardware details ( Amount of RAM,CPU ... ) of UCS-E160S-M3/K9 in that router ? I tried a lot of show commands but could not find it.
Thank you
Solved! Go to Solution.
11-12-2021 04:45 AM - edited 11-12-2021 04:46 AM
Hello
I found the commands
hw-module subslot 1/0 session imc
scope chassis
E160S-FOC213836G5 /chassis # show dimm detail
11-11-2021 08:35 AM
Have a look at Table 2
M.
11-11-2021 10:03 PM - edited 11-11-2021 10:04 PM
Yeah but i want to see current values on UCS-E160S-M3/K9 , documentation says 8 - 64 GB DRAM
11-11-2021 11:36 PM
- Perhaps you may get these values with show tech-support , and scrutinize the output.
M.
11-12-2021 12:46 AM
there is a lot of info but not that
Hello
scope chassis
