Unable to change parts of device configuration in prime infrastructure 3.9
itsec123
Hello everyone,
I successfully added some devices to my prime infrastructure 3.9 using SNMP and SSH credentials. Now the devices are all in state "managed". But I am unable to change the device configuration or at least parts of it. I can change des Interfaces, VLANs and ACLs but some other features are not showed in configuration tab. For example I want to turn on the scp server. I dont see any error messages. What am I doing wrong?
Mark Elsen
 - Have a look at the compatibility information :
          https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-9/supported/devices/PI39-Supported-Device-List.xlsx
  Meaning  , you also need to look at the minimum IOS/XE  software  versions needed on the device for the particular prime version you are using.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
