Unable to discover IP address and hostnames using Campus Manager UT
josephn
  I'm using Campus Manager version 5.2.1 and had installed patch to support UT for Nexus 7000. I'm having trouble in discovering IP address and hostname for each of the active MAC address that had been discovered. I tried initializing the Campus db few times and perform major acquistion but my attempts had failed. My LMS is on version 3.2. This is happening for all server access switches in which the default gateway is the Nexus 7000 router.
Any idea or help to resolve this problem is very much appreciated as I'm lost of new idea.
Thanks.
Joseph
Michel Hegeraat
Level 7
Level 7
So the switches are all managed in campus and so is the Nexus 7K?
And you have verfied for some servers  the the default gateway is in fact and interface of the Nexus?
You can start by checking if the Nexus has the devices you wish to see in its arp cache.
I guess "sh arp" should work on NX-OS. LMS should query the arp tables using SNMP and see the same results.
Cheers,
Michel
