unable to ping and acces ssh on switch Cisco 2960xr 48 port
statio
hi everyone
when changing my cisco Cisco 2960xr 24 port to another switch Cisco 2960xr 48 port i was unable to acces ssh
NB: i upload the config file of the 24 port to the 48 port
here is my config
interface Vlan1
ip address 192.168.0.116 255.255.254.0
no ip route-cache
shutdown
ip default-gateway 192.168.0.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh time-out 60
ip ssh logging events
ip ssh version 2
snmp-server community forescout RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 192.168.0.198 forescout
snmp mib flash cache
line con 0
logging synchronous
login local
history size 200
line vty 0 4
logging synchronous
login local
line vty 5 15
logging synchronous
login local
transport input ssh
end
SW-2960XR-Risler#exit
can you help me please
cordially
2 Accepted Solutions
Mark Elsen
               - You may need to create the crypto key(s) again (too) : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_3_e/consolidated_guide/b_1523e_consolidated_2960x_cg/b_consolidated_152ex_2960-X_cg_chapter_0100110.pdf
 M.
carstenlymann1
yes create a new crypto key should get you running
conf terminal
crypto key generate rsa
2048 bits is currently recommended
Please remember to select a correct answer and rate helpful posts
/ Carsten
6 Replies 6
Mark Elsen
 M.
thank you for you answer , i shall try and get you back
cordially
Thank you marce1000
carstenlymann1
conf terminal
/ Carsten
statio
hi every one ,
i tried to regenerate the ssh key but the issue still the same
SW-2960XR-Risler#show ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 60 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-959778176
Modulus Size : 1024 bits
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQClCn92ynomKPUsJFOwU1wLjdgbsSR+LOZtcCkLeCR3
IrhrE4pH0eyrrJgh4B9EBBifyK0f7becNTW4G/HOTUZDk0CmaGYiaqFr7wv7bx9wk1kLbwNDZApoQRQK
GxcX5w3lmQw7dspoWvQWPAbk69vEzuUMSQmbsR30f3M2MJ91Dw==
SW-2960XR-Risler#show ssh
%No SSHv2 server connections running.
Do you have other solutions for my issue
cordially
interface Vlan1
no ip route-cache
shutdown"
Your interface vlan is shutdown.
interface vlan 1
no shutdown
Save config
wr
