unable to ping and acces ssh on switch Cisco 2960xr 48 port
statio
Visitor
hi everyone
when changing my cisco Cisco 2960xr 24 port to another switch Cisco 2960xr 48 port i was unable to acces ssh
NB: i upload the config file of the 24 port to the 48 port
here is my config
interface Vlan1
ip address 192.168.0.116 255.255.254.0
no ip route-cache
shutdown
ip default-gateway 192.168.0.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh time-out 60
ip ssh logging events
ip ssh version 2
snmp-server community forescout RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 192.168.0.198 forescout
snmp mib flash cache
line con 0
logging synchronous
login local
history size 200
line vty 0 4
logging synchronous
login local
line vty 5 15
logging synchronous
login local
transport input ssh
end
SW-2960XR-Risler#exit
can you help me please
cordially
2 Accepted Solutions
Mark Elsen
               - You may need to create the crypto key(s) again (too) : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_3_e/consolidated_guide/b_1523e_consolidated_2960x_cg/b_consolidated_152ex_2960-X_cg_chapter_0100110.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
carstenlymann1
Level 4
Level 4
yes create a new crypto key should get you running
conf terminal
crypto key generate rsa
2048 bits is currently recommended
Please remember to select a correct answer and rate helpful posts
/ Carsten
6 Replies 6
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
thank you for you answer , i shall try and get you back
cordially
Thank you marce1000
carstenlymann1
Level 4
Level 4
conf terminal
/ Carsten
statio
Visitor
hi every one ,
i tried to regenerate the ssh key but the issue still the same
SW-2960XR-Risler#show ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 60 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-959778176
Modulus Size : 1024 bits
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQClCn92ynomKPUsJFOwU1wLjdgbsSR+LOZtcCkLeCR3
IrhrE4pH0eyrrJgh4B9EBBifyK0f7becNTW4G/HOTUZDk0CmaGYiaqFr7wv7bx9wk1kLbwNDZApoQRQK
GxcX5w3lmQw7dspoWvQWPAbk69vEzuUMSQmbsR30f3M2MJ91Dw==
SW-2960XR-Risler#show ssh
%No SSHv2 server connections running.
Do you have other solutions for my issue
cordially
interface Vlan1
no ip route-cache
shutdown"
Your interface vlan is shutdown.
interface vlan 1
no shutdown
Save config
wr
