Unable to ping gateway
shoong001
We are having issues pinging the gateway after an outage happened. We are unable to ping out from the cisco. Please see below for config
ciscoasa(config)# show running-config
: Saved
: Serial Number: FCH18457D65
: Hardware:   ASA5512, 4096 MB RAM, CPU Clarkdale 2793 MHz, 1 CPU (2 cores)
ASA Version 9.8(3)8
hostname ciscoasa
enable
names
no mac-address auto
interface GigabitEthernet0/0
 description to WAN
 nameif outside
 security-level 0
 ip address 216.164.164.218 255.255.255.248
interface GigabitEthernet0/1
 description to LAN
 nameif CORPNET52
 security-level 100
 ip address 10.130.52.1 255.255.252.0
interface GigabitEthernet0/1.13
 description to VPN
 no vlan
 no nameif
 security-level 100
 ip address 10.130.13.1 255.255.255.0
interface GigabitEthernet0/1.62
 description to GUEST
 no vlan
 no nameif
 security-level 20
 ip address 10.130.62.1 255.255.255.0
interface GigabitEthernet0/2
 description to VOICE
 shutdown
 nameif VOICE42
 security-level 100
 ip address 10.130.42.1 255.255.255.0
interface GigabitEthernet0/3
 description to MGMT
 shutdown
 nameif MGMT10
 security-level 100
 ip address 10.130.10.1 255.255.255.0
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 100
boot system disk0:/asa983-8-smp-k8.bin
ftp mode passive
object network 10.130.52.0_22
 subnet 10.130.52.0 255.255.252.0
object network 10.120.52.0_22
 subnet 10.120.52.0 255.255.252.0
access-list 100 extended permit ip object 10.130.52.0_22 object 10.120.52.0_22
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu CORPNET52 1500
mtu VOICE42 1500
mtu MGMT10 1500
mtu management 1500
no failover
no monitor-interface outside
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit any echo-reply outside
icmp permit any echo outside
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 8192
nat (CORPNET52,outside) source static 10.130.52.0_22 10.130.52.0_22 destination static 10.120.52.0_22 10.120.52.0_22 no-proxy-arp route-lookup
nat (CORPNET52,outside) after-auto source dynamic any interface
route outside 0.0.0.0 0.0.0.0 216.164.164.217 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
aaa authentication login-history
http server enable
http 192.168.1.0 255.255.255.0 management
http 10.130.0.0 255.255.255.0 CORPNET52
no snmp-server location
no snmp-server contact
crypto ipsec ikev1 transform-set myset esp-aes esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 20 match address 100
crypto map outside_map 20 set pfs
crypto map outside_map 20 set peer 128.177.20.34
crypto map outside_map 20 set ikev1 transform-set myset
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev1 enable outside
crypto ikev1 policy 1
 authentication pre-share
 encryption aes
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh scopy enable
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group14-sha1
console timeout 0
dhcpd dns 8.8.8.8 4.2.2.2
dhcpd address 10.130.52.5-10.130.52.254 CORPNET52
dhcpd enable CORPNET52
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
username
username
 service-type admin
tunnel-group 128.177.20.34 type ipsec-l2l
tunnel-group 128.177.20.34 ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group 192.168.1.1 type ipsec-l2l
tunnel-group 192.168.1.1 ipsec-attributes
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:d214ef7e0a9797c8904b211b378fc5a6
: end
8 Replies 8
Is the issue related only to PING or you cannot surf in Internet at all?
Can you ping Internet from the firewall console?
What is your IP? And what is the PING destination?
Regards.
unable to ping the internet from the firewall console.
So, if the issue is only related to icmp, can you try to configure an acl to permit icmp from outside to inside?
Something like this:
access-list outside_access_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in extended permit icmp any any unreachable
and apply the acl using the command:
access-group outside_access_in in interface outside
Let me know the result.
Regards.
still unable to ping out of the cisco. can't even hit our ISP gateway. we are unable to route out.
To be honest I don't understand if the issue is related to all IP traffic or only to PING (icmp).
Is the outside interface up?
show int g0/0
Is the ARP table consistent?
show arp
What is connected to outside?
Can be the ISP CPE stuck?
Regards.
Interface is up
what do you mean by is the arp table consistent? what will i be looking for?
what is ISP CPE?
Please, from the firewall console test a ping to the default gateway and after that execute the 'show arp' command.
Post the output.
Regards.
CSCO11304974
Try to ping WAN interface ip : # Ping 216.164.164.218
Try to ping LAN interface ip : # 10.130.52.1
Try to ping Voice interface ip : # 10.130.42.1
And ping Mgmt interface ip : # 10.130.10.1
Praveen.N
