unknown devices is CW LMS 3.0
arun
some device appears as "Unknown device" in DCR. When i look in Common services, i got a question mark icon next to the device.
Moreover, RME is not able to fetch the config. i cannot find the solution for this. thanks in advance.....
24 Replies 24
Ok, i will ask my server admin to do that....
i deleted 10.99.1.11 and readded the same.Icserver log has been attached
This sysObjectID of this switch is 1.3.6.1.4.1.9.1.875 which is not supported in RME 4.1. You need to upgrade to LMS 3.0.1, and apply the device packages as I previously stated to get support for this device.
so it should not support all the 4506-E switches right?
so it should not support all the 4506-E switches right?.As i told previously , i dont have issue with all the 4506-E switches , having issue with only few switches(8 to 10 out of 40)....
Any true 4506-E with this sysObjectID (1.3.6.1.4.1.9.1.875) will not be supported until you upgrade to LMS 3.0.1, and apply all of the available RME 4.1.1 device packages.
ok. Then what about these devices
CISCO2821
CISCO3845-HSC/K9
Yes, these devices are supported as well in RME 4.1.1.
how can i upgrade it to LMS 3.0.1. is there any documents available with guidelines.
