04-17-2009 04:49 PM
some device appears as "Unknown device" in DCR. When i look in Common services, i got a question mark icon next to the device.
Moreover, RME is not able to fetch the config. i cannot find the solution for this. thanks in advance.....
04-19-2009 12:54 PM
Ok, i will ask my server admin to do that....
04-19-2009 04:57 PM
04-19-2009 05:04 PM
This sysObjectID of this switch is 1.3.6.1.4.1.9.1.875 which is not supported in RME 4.1. You need to upgrade to LMS 3.0.1, and apply the device packages as I previously stated to get support for this device.
04-20-2009 05:25 PM
so it should not support all the 4506-E switches right?
04-20-2009 05:29 PM
so it should not support all the 4506-E switches right?.As i told previously , i dont have issue with all the 4506-E switches , having issue with only few switches(8 to 10 out of 40)....
04-20-2009 06:32 PM
Any true 4506-E with this sysObjectID (1.3.6.1.4.1.9.1.875) will not be supported until you upgrade to LMS 3.0.1, and apply all of the available RME 4.1.1 device packages.
04-20-2009 06:53 PM
ok. Then what about these devices
CISCO2821
CISCO3845-HSC/K9
04-20-2009 06:59 PM
Yes, these devices are supported as well in RME 4.1.1.
04-22-2009 12:18 AM
how can i upgrade it to LMS 3.0.1. is there any documents available with guidelines.
04-22-2009 03:51 AM
Installation and setup guides for CiscoWorks LMS Common Services versions are posted here: http://www.cisco.com/en/US/products/sw/cscowork/ps3996/prod_installation_guides_list.html
Those for RME are here:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/prod_installation_guides_list.html
