Using EVE-NG to simulate ASA 5525
irbk
I'm brand new to EVE-NG.  A CCIE associate of mine showed it too me and it looked really cool at first.  What I'd love to be able to do is take my current ASA 5525-x config into EVE-NG and do things to it like update the ASDM, update the ASA software, make major changes to the rules, etc, to see how things are going to work before I do it in the production system.  Unfortunately, I'm not finding any information that would allow me to take my ASA .bin file, convert it into a qcow2 file, so that I could run it in EVE-NG.  Is this possible or am I restricted to running whatever the community version of the ASA is (or an ASAv).  I really want to get EVE-NG to be a 1-to-1 to production as much as possible.
try gns3 vm, it excellent for ASA
Yeah, I've tried GNS3 in the past with little success.  The boss has tasked me with setting up EVE-NG so that's what I've got to do.  Big picture is that we would like to eventually map out our entire network in EVE-NG so we can test changes in the lab before touching actual production equipment.
Gns3 or eve-ng you need vmware and pc with at least cpu 8 cores and 32 ram.
I use pc with cpu 12 cores and 32 ram.
I can run multi asa as I want and it stable.
We are running in a dedicated VMWare hosts environment with plenty of storage, cpu, and ram.  None of it is a concern, but none of it matters if I can't get a 1-to-1 between the EVE-NG environment and live environment.
