UTU functionality
dmitry
I need to replicate the functionality of the Cisco's User Tracking Utility via a WEB based tool (cgi with perl), I can do it via calls to campus/bin/ut -cli but I was wondering if the Cisco's UTU uses some kind of SOAP / xmlrpc calls to the CM, which I could use?
yjdabear
Does the solution *have to* use xmlrpc/SOAP? Without that as a hard requirement, empirically speaking, it seems that one could potentially just adapt the Perl sample code "Accessing Database Using ODBC Access Method" to query the LMS DB from a remote server against the End_Hosts view, which is equivalent to what UTU provides (in my perception).
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/database_schema/guide/dbviews.html#wp69456
Sample Code to Access Database From a Remote Server
After you have copied the required files from CiscoWorks Server to remote server and created DSNs, you can access the CiscoWorks database from a remote server.
See the following sections for the sample code to access the CiscoWorks database:
Accessing Database Using Jconnect JDBC Access Method
Accessing Database Using iAnyWhere JDBC Access Method
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/database_schema/guide/dbviews.html#wp143337
Exposed Database Views and Tables
Table 1 lists the database views or tables that are exposed in CiscoWorks applications.
Table 1     Exposed Database Views and Tables
CiscoWorks Application
Name of Views or Tables
Common Services (CS) Views
Network_Devices
Job_Details
Campus Manager (CM) Views
End_Hosts
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/database_schema/guide/dbviews.html#wp136881
End_Hosts View Details
The End_Hosts view displays the end host details from Campus Manager application, as explained in Table 4.
Table 4     End_Hosts Schema Details
Column Name
Column Type
Constraints
Column Description
HostName
varchar(64)
Null
Name of the end host
UserName
varchar(64)
Null
Logged In User name
IPAddress
varchar(15)
Null
IP Address of the end host
SubnetMask
varchar(15)
Null
Subnet mask of the device to which end host is connected
MACAddress
varchar(17)
Null
MAC Address of the end host
DeviceName
varchar(64)
Null
Device Name  (Host Name) to which the end host is connected
Device
varchar(15)
Null
Device IP Address to which the end host is connected
LastSeen
varchar(32)
Null
Time at which end host is last seen
Port
varchar(32)
Null
Name of the port where the end host is connected
VLAN
varchar(32)
Null
VLAN name.
Example: VLAN100
Subnet
varchar(15)
Null
Subnet of the device to which end host is connected
Notes
varchar(255)
Null
Notes entered by the user
PrefixLength
integer
Null
Subnet prefix length
PortDuplex
varchar(32)
Null
Mode of the port to where end host is connected
VTPDomain
varchar(32)
Null
VTP Domain Name of the device where the end host is connected.
VlanId
integer
Null
VLAN ID
Example: 100
PortName
varchar(255)
Null
Port Description entered by the user
IPv6Address
varchar(150)
Null
IPV6 address, if configured
dot1xEnabled
varchar(15)
Null
dot1x enabled status.
The value could be True or False.
associatedRouters
varchar(250)
Null
Comma separated list of routers in the subnet
5 Replies 5
Martin Ermel
UTU talks to a servlet named UTBandServlet.
I also did some investigations to make use of this feature but currently have no time to follow-up on this
yjdabear
Network_Devices
Job_Details
End_Hosts
Column Name
Column Type
Constraints
Column Description
HostName
varchar(64)
Null
UserName
varchar(64)
Null
Logged In User name
IPAddress
varchar(15)
Null
SubnetMask
varchar(15)
Null
MACAddress
varchar(17)
Null
DeviceName
varchar(64)
Null
Device
varchar(15)
Null
LastSeen
varchar(32)
Null
Port
varchar(32)
Null
VLAN
varchar(32)
Null
VLAN name.
Example: VLAN100
Subnet
varchar(15)
Null
Notes
varchar(255)
Null
PrefixLength
integer
Null
PortDuplex
varchar(32)
Null
VTPDomain
varchar(32)
Null
VlanId
integer
Null
VLAN ID
Example: 100
PortName
varchar(255)
Null
IPv6Address
varchar(150)
Null
dot1xEnabled
varchar(15)
Null
associatedRouters
varchar(250)
Null
Thanks for the feedbacks, I'm terrified by the LMS DBs (had to reinitialize different DBs in the past due to some corruptions), would prefer to stay away from the direct DB access
The direct database access in LMS 3.2 is perfectly safe.  In fact, the actual tables which contain the data are not exposed to users.  Instead, new read-only views are created to provide the documented data.
Checked the http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_campus_manager/5.2/user/guide_pb/dee.html
and it had the info on the servlet that can be accessed remotely (a wrapper for cwexport / ut), I just realized that they have a common issue, which is I cannot request the info for a particular host / user, instead they will provide all the hosts / users and then the client will have to sort it out, the problem is with the amount of data. It looks like the access to the DB would be the most appropriate way
