Virtual Port Channel Configuration help
Hogan.BrendanT1
I rarely use VPCs so I could use some help figuring out what is wrong in this configuration.  I am setting up a VPC between 4 devices, 2 nexus 5548s and 2 nexus 91380s.
The 2 nexus 5548s are configured as such:(config is for switch, .9 is the same but points to .8) and go between mgmt0:
int mgmt0
ip address 10.18.65.8/24 (switch 2 is .9/24)
vrf context management
ip route 0.0.0.0 10.18.65.1
vpc domain 11
role priority 1000
peer-keepalive destination 10.18.65.9
int Eth1/1-2 (these are the uplinks from the 91380s interfaces 1/47 and 1/48)
channel-group 11 mode active
int po11
vpc peer-link
switchport mode trunk
switchport trunk allowed vlan 951, 1944
Nexus 91380 config
vpc domain 11
role priority 1000
int Eth1/43-44 (these interfaces are used to talk between the 2 Nexus 91380s)
int po11
vpc 11
int Eth1/47-48 (these interfaces talk back to the Nexus 5548s)
When I have this configured as such the 2 nexus 5548s can see that each exists but the vpc is not up, almost all checks fail (the only that doesnt is the vlan check).  So I know I am missing something, and maybe the way I have this pictured in my head wont actually work, but I could use some help getting them setup correctly..
Thank you in advance.
balaji.bandi
Can you post full config and show vpc output from both the switches.
below guide steps works,
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/configuration_guide_c07-543563.html
BB
