Virtual Route Forwarding (VRF) - simple config - ping won't work from PC, but ok from R1
Ivan Mamka
I might be missing some basics on how VRFs work. But Following is configuration GNS3 (question at the bottom, image attached):
PC4 -->(G2/0) R1 (G1/0.2)---> (G1/0.2) R2
PC4: ip 10.1.1.10 255.255.255.0 10.1.1.1
R1:
vrf definition sony
address-family ipv4
int g1/0.2
vrf forwarding sony
encapsulation dot1q 2
ip address 105.1.1.1 255.255.255.252
ip ospf 2 area 0
ip ospf network point-to-point
no shutdown
int gig2/0
vrf forwarding sony
ip address 10.1.1.1 255.255.255.0
no shutdown
R2:
int gig1/0.2
vrf forwarding sony
ip address 105.1.1.2 255.255.255.252
ip ospf 2 area 0
no shutdown
PC1: pint 10.1.1.1    <--- OK
PC1: ping 105.1.1.1 <--- OK
PC1: ping 105.1.1.2 <--- ICMP timeout
R1: ping vrf sony 105.1.1.2   <---- OK
Question: Why I can't ping interface of R2 from PC1 but I can ping it from R1?
Thought: If ICMP timeout means R1 has path to route but R2 not replying?
Thanks!:)
Francesco Molino
Is your OSPF up between R1 and R2? Or do you have any static route on R2 to reach out back the subnet 10.1.1.0/24 residing on R1?
Your 10.1.1.0/24 seems not being part of your OSPF, are you doing any redistribute connected?
Can you share the routing part of your config and also the output of (on all routers):
- sh run | s r o
- sh ip ospf nei
- sh ip route vrf sony
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
- sh run | s r o
- sh ip ospf nei
Francesco
