Visio stencils for SFPs?
Colin Higgins
Level 2
Level 2
Does Cisco have Visio stencils for SFP modules such as 10Gbs fiber, 100Gbs, etc?
I've looked all over the visio page on the cisco website, and found modules, but no SFPs.
Try Visio Cafe...
VSDfx-Generic  has a shape for an "Optic SFP+"
The Same shape, as far as I can tell is also in Dell-PowerEdge-RackServers.zip
Note that these are for the SFP's, NOT the transceivers that plug into them!  Although, if you need one for those, I'm sure I can create one for you, it's not really all that hard.
amadoriale
I would be fine also with the normals SFPs tbh - if I knew where to find them :D
Captain HoOmi
See attached post, I have used this one
Example:
** Please rate this post or accept the solution if it helped! :) **
That looks like a router module, how do you use it as an SFP?
Try Visio Cafe...
