VLAN CONFIGURATION AND ACL
Hi!
I am new in networking and I am trying to setup this networking.
I have supposed that I have these devices possible:
layer 2 switch, 24 port FE and 2 ports GE
router, 2 ports FE, 1 wan port(it doesnt metter, fiber or any)
In the router I have these ip:
WAN Port- Se 1/0 ip 200.1.1.2/24
FE Port- 192.168.1.1/24 (connected to the switch in center)
In the switch:
I have created 4 vlans:
Vlan10 10.10.10.1/24
Vlan20 10.10.20.1/24
Vlan30 10.10.30.1/24
Vlan40 10.10.40.1/24
DHCP enabled for all Vlans
GIG 0/1 configured as trunk port and connected to the router.
Fe 0/1-6 Part of Vlan10
Fe 0/7-12 Vlan20
Fe 0/13-18 Vlan30
Fe 0/19-24 Vlan40
Other switches are part of their own vlan giving IP
from the main switch.
What I want to do is to let vlan 10 to communicate with other
vlan20, 30 and 40 inbound and outbound.
From the other side I don't want to let vlans 20,30 and 40
to communicate with each other.
Also I want to be sure that all end devices to have
internet access!
Is it possible to this with a layer2 switch and a router? If yes, how?
I will appreciate it if someone gives me a clear guide and explaination how to this
kind of configuration!
Thank you in advance!
balaji.bandi
try basic config and improve better once you understand the concept
access-list 10 permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 10 permit ip 10.10.10.0 0.0.0.255 10.10.30.0 0.0.0.255
access-list 10 permit ip 10.10.10.0 0.0.0.255 10.10.40.0 0.0.0.255
access-list 20 permit ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 30 permit ip 10.10.30.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 40 permit ip 10.10.40.0 0.0.0.255 10.10.10.0 0.0.0.255
Int Vlan 10
ip access-group 10 out
Int Vlan 20
ip access-group 20 out
Int Vlan 30
ip access-group 30 out
Int Vlan 40
ip access-group 40 out
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vacl.html
BB
