05-23-2006 01:02 PM
Hi everyone.
When we try to update the software repository with images from the Switches, we recieve the following errormessage in the logfile:
LYR000C001#copy flash:vlan.dat tftp://Default Not Defined/rep_sw_720920598628557696^M
^^M
% Invalid input detected at '^' marker.^M ^M
Does anyone have an idea?
Best Regards
Jarle Steffensen
05-23-2006 01:17 PM
What version of RME are you running?
Does your CiscoWorks server have more than one NIC?
05-24-2006 05:11 AM
We use RME 4.0.4 and do have multihomed hosts.
We have changed the gatekeeper file:
/opt/CSCOpx/lib/vbroker/gatekeeper.cfg
to point to the correct network card, so these settings should also be ok.
Any ideas ?
Greetings
Jarle
05-24-2006 06:08 AM
Try going to RME > Admin > System Preferences > RME Device Attributes and enter your server's ip address in the RME ID field.
Click on Apply.
Try the job.
Please let me know if that helps.
05-30-2006 05:02 AM
Even after Setting the Server IP Address in the
- RME - Admin - System Preferences - RME Device Atribute the same error message still occures:
^^M
BTW : The "^M" = Carrage Return so dont worry about it.
regards
Jarle
