vlan/subnet info report on LMS
randomjoe1
We have lms3.2 sp1 (soon to be upgrading to 4)
Is there a way (report or something else) where if I submit a VLAN, LMS will return what subnets are associated?
example:
[user input]vlan 10
[lms output]1.1.1.1/24
[lms output]2.2.2.2/24
[lms output]3.3.3.3/24
Nael Mohammad
Level 5
Level 5
In LMS 3.2 Campus Manager 5.2, use the report generator for VLans.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_campus_manager/5.2/user/guide_pb/vlanvtp.html#wpxref26730
Step 1 Select Campus Manager > Visualization > Topology Services from the LMS Portal.
The Topology Services Main Window appears.
Step 2 Select a view that contains the device, switch cloud, or the VTP Domain for which you want to view the report.
This view is in the Tree View in the Topology Services Main Window.
Step 3 Select Reports > VLAN Report from the menu.
or
Right-click the VTP Domain or the device, and select Display View.
The Network Topology window appears.
Step 4 Select the device or the switch cloud.
Step 5 Right-click and select VLAN Report from the popup menu.
or
Select Reports  > VLAN Report.
The VLAN Report window appears.
Interpreting VLAN Reports
The following information is displayed at the top of the report:
Device Name
Device IP
Device Type
Domain
