12-30-2010 02:33 AM
In DFM we get the following messages:
To start with what is a "VoltageSensor" and where is it for?
Why is the threshold between 1 and 5 and the currant value 0?
How can we get rid of it (I figured the filtering out part allready out myself )
Please can anyone explain this, or is this again another Ciscoworks bug?
12-30-2010 11:54 AM
Looks like there're multiple possible causes:
01-02-2011 11:00 PM
Thanks for the reply, I actually did see that
message before posting mine.
It didn't answer my question though, his problem is different than ours.
Maybe someone knows the real answer to my questions?
01-03-2011 09:43 PM
This is a known limitation of DFM. Certain GBIC/XenPak modules do not have a voltage sensor. In that case, they will report a voltage of 0 (which is fine). In this case, you can unamange those interface voltage sensors that are not present under DFM > Device Management > Device Details.
11-22-2011 06:19 AM
Hi Joseph,
I am facing the same voltage OutOfRange problem with two VSS systems using 10GB X2 modules which report voltage as 0. Can you please adapt the above solution to LMS 4.0.1 GUI ? I could not find DFM->Device Management->Device Details in LMS 4.0
Thank you,
Adrian
11-22-2011 08:11 AM
in LMS 4.1 the Fault Device Details can be accessed here:
Monitor > Fault Settings > Setup > Fault Device Details
11-22-2011 09:33 AM
Thanks Martin. I did find the location you mentioned but I receive an error when a try to view the details of any device. The error is :
Cannot generate Device Details display.
Please see the DeviceManagement.log file for more information.
I do not have access to the file at this moment so any suggestions regarding the cause of this error are welcomed.
Adrian
11-23-2011 02:03 AM
this could be a process failure. Can you post the output of "pdshow" and "pdshow -brief" and when you have access to the log the DeviceManagement.log
11-23-2011 03:32 AM
Below are the outputs that you requested :
Process State Pid
UPMDbEngine Program started - No mgt msgs received 2236
UPMDbMonitor Running normally 2432
Tomcat Program started - No mgt msgs received 808
TomcatMonitor Running normally 4768
Apache Program started - No mgt msgs received 4336
RMEDbEngine Program started - No mgt msgs received 2124
Proxy Program started - No mgt msgs received 6184
NameServer Program started - No mgt msgs received 6192
NameServiceMonitor Running normally 6256
EDS Running normally 6344
LicenseServer Program started - No mgt msgs received 6920
IpmDbEngine Program started - No mgt msgs received 676
INVDbEngine Program started - No mgt msgs received 1308
FHPurgeTask Transient terminated 0
FHDbEngine Program started - No mgt msgs received 1924
ESS Program started - No mgt msgs received 7012
EssMonitor Running normally 7120
EventFramework Program started - No mgt msgs received 6324
PMServer Running normally 6472
SyslogCollector Running normally 7060
EPMDbEngine Program started - No mgt msgs received 1832
EPMServer Running normally 7008
FHServer Running normally 428
diskWatcher Running normally 5068
DFMMultiProcLogger Program started - No mgt msgs received 5044
DFMLogServer Program started - No mgt msgs received 5036
DFMCTMStartup Administrator has shut down this server 0
DfmBroker Program started - No mgt msgs received 6724
DfmServer Running normally 7568
DfmServer1 Running normally 7584
DCRDevicePoll Never started 0
CSSCPServer Program started - No mgt msgs received 7592
CSRegistryServer Running normally 7600
CSDiscovery Never started 0
CmfDbEngine Program started - No mgt msgs received 1580
CmfDbMonitor Running normally 8112
DCRServer Running normally 7240
CMFOGSServer Program started - No mgt msgs received 8248
EssentialsDM Running normally 8268
ConfigMgmtServer Running normally 8640
ConfigUtilityService Running normally 8648
ICServer Running normally 8744
EnergyWise Running normally 8972
PMCOGSServer Program started - No mgt msgs received 8980
IPMOGSServer Program started - No mgt msgs received 8988
TISServer Program started - No mgt msgs received 8996
DFMOGSServer Program started - No mgt msgs received 9308
InventoryCollector Running normally 9640
Interactor Program started - No mgt msgs received 10008
InventoryCollector1 Program started - No mgt msgs received 10016
Interactor1 Program started - No mgt msgs received 6804
NOSServer Running normally 6856
PTMServer Running normally 6760
UPMProcess Running normally 9920
EDS-GCF Running normally 9980
jrm Running normally 6464
1018 Never started 0
1605 Never started 0
1905 Never started 0
1928 Never started 0
1932 Never started 0
1964 Never started 0
3721 Never started 0
3722 Never started 0
3847 Never started 0
5266 Never started 0
CTMJrmServer Running normally 10824
ChangeAudit Program started - No mgt msgs received 10032
SyslogAnalyzer Running normally 11024
DataPurge Administrator has shut down this server 0
IPMProcess Program started - No mgt msgs received 10272
5341 Running normally 2908
ANIDbEngine Program started - No mgt msgs received 1540
ANIServer Running with busy flag set 11600
UTMajorAcquisition Program started - No mgt msgs received 3056
MACUHIC Running normally 11860
UTLITE Running normally 11868
UTManager Running normally 11876
VNMServer Program started - No mgt msgs received 11884
WlseUHIC Running normally 11892
AdapterServer1 Program started - No mgt msgs received 11900
AdapterServer Program started - No mgt msgs received 11916
2011|17:27:18.731|ERROR|TIS.KdmCategory|TP-Processor10|DeviceSummaryCollector|authorizeTask|.|Authorization Failure
30-May-2011|18:41:22.410|ERROR|TIS.KdmCategory|TP-Processor2|DeviceSummaryCollector|authorizeTask|.|Authorization Failure
07-Jul-2011|09:12:31.288|ERROR|TIS.KdmCategory|TP-Processor3|KdmSecurity|authorizeTask|.|Authorization Failure
10-Jul-2011|16:33:19.611|ERROR|TIS.KdmCategory|TP-Processor1|KdmSecurity|authorizeTask|.|Authorization Failure
18-Jul-2011|13:51:59.411|ERROR|TIS.KdmCategory|TP-Processor6|KdmSecurity|authorizeTask|.|Authorization Failure
30-Jul-2011|23:31:11.753|ERROR|TIS.KdmCategory|TP-Processor5|KdmSecurity|authorizeTask|.|Authorization Failure
02-Aug-2011|13:04:52.077|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
09-Aug-2011|16:44:54.798|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
10-Aug-2011|14:10:40.555|ERROR|TIS.KdmCategory|TP-Processor22|KdmSecurity|authorizeTask|.|Authorization Failure
10-Aug-2011|14:10:58.098|ERROR|TIS.KdmCategory|TP-Processor12|KdmSecurity|authorizeTask|.|Authorization Failure
11-Aug-2011|15:24:02.533|ERROR|TIS.KdmCategory|TP-Processor1|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:16:06.014|ERROR|TIS.KdmCategory|TP-Processor3|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:19:08.346|ERROR|TIS.KdmCategory|TP-Processor1|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:30:10.398|ERROR|TIS.KdmCategory|TP-Processor8|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:33:11.239|ERROR|TIS.KdmCategory|TP-Processor9|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:49:15.310|ERROR|TIS.KdmCategory|TP-Processor9|KdmSecurity|authorizeTask|.|Authorization Failure
17-Aug-2011|16:53:16.287|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
18-Aug-2011|14:30:37.604|ERROR|TIS.KdmCategory|TP-Processor14|KdmSecurity|authorizeTask|.|Authorization Failure
18-Aug-2011|14:33:18.055|ERROR|TIS.KdmCategory|TP-Processor5|KdmSecurity|authorizeTask|.|Authorization Failure
06-Sep-2011|15:01:51.008|ERROR|TIS.KdmCategory|TP-Processor19|KdmSecurity|authorizeTask|.|Authorization Failure
27-Oct-2011|20:56:34.988|ERROR|TIS.KdmCategory|TP-Processor20|KdmSecurity|authorizeTask|.|Authorization Failure
11-Nov-2011|09:36:21.908|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
14-Nov-2011|10:50:42.119|ERROR|TIS.KdmCategory|TP-Processor16|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|14:59:00.309|ERROR|TIS.KdmCategory|TP-Processor11|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:03:51.176|ERROR|TIS.KdmCategory|TP-Processor5|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:04:26.373|ERROR|TIS.KdmCategory|TP-Processor6|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:08:46.310|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:11:30.518|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:40:36.129|ERROR|TIS.KdmCategory|TP-Processor12|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|15:40:36.148|ERROR|TIS.KdmCategory|TP-Processor12|DMException|DMException()|.|Invalid device list
22-Nov-2011|15:40:36.148|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
at com.cisco.nm.trx.kdm.utils.DMExportToXML.setSelectedDevices(DMExportToXML.java:40)
at com.cisco.nm.trx.kdm.actionform.DeviceReportsActionForm.setSelectedDevices(DeviceReportsActionForm.java:56)
at com.cisco.nm.trx.kdm.action.DeviceReportsAction.perform(DeviceReportsAction.java:322)
at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:509)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at com.cisco.nm.cmf.util.AjaxAccessFilter.doFilter(AjaxAccessFilter.java:189)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:775)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:704)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:897)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:662)
22-Nov-2011|15:40:36.149|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|15:40:51.034|ERROR|TIS.KdmCategory|TP-Processor12|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|15:40:51.035|ERROR|TIS.KdmCategory|TP-Processor12|DMException|DMException()|.|Invalid device list
22-Nov-2011|15:40:51.035|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|15:40:51.035|ERROR|TIS.KdmCategory|TP-Processor12|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|15:43:10.039|ERROR|TIS.KdmCategory|TP-Processor2|KdmSecurity|authorizeTask|.|Authorization Failure
22-Nov-2011|15:52:37.637|ERROR|TIS.KdmCategory|TP-Processor5|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|15:52:37.638|ERROR|TIS.KdmCategory|TP-Processor5|DMException|DMException()|.|Invalid device list
22-Nov-2011|15:52:37.638|ERROR|TIS.KdmCategory|TP-Processor5|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|15:52:37.639|ERROR|TIS.KdmCategory|TP-Processor5|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|16:04:10.184|ERROR|TIS.KdmCategory|TP-Processor6|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|16:04:10.185|ERROR|TIS.KdmCategory|TP-Processor6|DMException|DMException()|.|Invalid device list
22-Nov-2011|16:04:10.185|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|16:04:10.185|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|16:10:05.480|ERROR|TIS.KdmCategory|TP-Processor7|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|16:10:05.482|ERROR|TIS.KdmCategory|TP-Processor7|DMException|DMException()|.|Invalid device list
22-Nov-2011|16:10:05.483|ERROR|TIS.KdmCategory|TP-Processor7|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|16:10:05.483|ERROR|TIS.KdmCategory|TP-Processor7|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
22-Nov-2011|19:28:19.977|ERROR|TIS.KdmCategory|TP-Processor6|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
22-Nov-2011|19:28:19.980|ERROR|TIS.KdmCategory|TP-Processor6|DMException|DMException()|.|Invalid device list
22-Nov-2011|19:28:19.980|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
22-Nov-2011|19:28:19.980|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
23-Nov-2011|11:43:12.740|ERROR|TIS.KdmCategory|TP-Processor6|kdmDeviceReportsProxy|getDeviceStatusList()|.|Authorized device list is null
23-Nov-2011|11:43:12.742|ERROR|TIS.KdmCategory|TP-Processor6|DMException|DMException()|.|Invalid device list
23-Nov-2011|11:43:12.742|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|com.cisco.nm.trx.kdm.utils.DMException: Invalid device list
23-Nov-2011|11:43:12.742|ERROR|TIS.KdmCategory|TP-Processor6|DeviceReportsAction|perform()|.|Exception in Device Reports. Deleting temporary files..
If you need it I can also post the output of pdshow but it is rather large.
Adrian
