VRRP functionality implementation
robertvidal
Frequent Visitor
Frequent Visitor
I need ti implement a network solution using VRRP functionality. My questions is, witch Switch L3 or Router model have this functionality implemented?
Thank you.
5 Replies 5
Mark Elsen
  - Use this app and select the feature (vrrp) accordingly : https://cfnng.cisco.com/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thank you! But the thing is, i have an ASR9001 and i cannot find this platform on the link that you send me, in order to understand if it is cpable to support VRRP and on witch software version.
Thkx
balaji.bandi
Its all depends on model and License running on that switch,.  show version, show License give you information
or as suggested look for feature navigator for more informaiton and suipport.
BB
Ok, but i'm with some difficult to understand if ASR9001 is capable to support VRRP or not.. Thank you.
