VSS Device problem
     We have installed Ciscoworks LMS 3.2 on Windows Server 2003 Enterprise edition. We are trying to add 6500 Switch which is in vss mode, CDA job was successful but when we are accessing the switch from cisco view it is showing only one chassis
We have one WISM and one FWSM card in each 6500 switch this cards is showing Unsupported card in cisco view.
Following is the software version of RME and Cisco View
RME 4.3.1
Cisco View 6.1.9
ccarring
Greetings,
Referring to the LMS 3.2 compatibility guide here:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
It does not mention VSS mode in the compatibility guide, but I think the latest updates to RME and CiscoView will add the support you are looking for:
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268439477
Thanks for the reply .
I had opened a TAC case and as per the engg there is a new package that is currently being tested by the developers that will provide support.
Below is the Bug ID Details filed for the issue
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtf43230
