We need to create a EEM Script to reload the Router nightly.
kegutier
Hello Experts,
I hope this finds you well!
Can anyone please help me out to validate the EEM Script to reload the
Router nightly?
2911-A(config)#DO SH CLOCK
18:50:10.462 UTC Mon Jun 1 2015
2911-A(config)#event manager applet RELOAD
2911-A(config-applet)#DESCription "RELOAD"
2911-A(config-applet)#EVENt timer pattern 19:10:17.965
2911-A(config-applet)#action cli reload
2911-A(config-applet)#exit
Would you please take a look at the syntaxes I have used and correct me on what I am missing on it.
Thank you for your help!
Best regards,
jossabor
Kelvin
A simple script that will trigger the reload every night is the following:
event timer cron cron-entry @midnight
action 1 reload
Jose Saborio
kegutier
Thank you so  much for your help!
regards,
