%WEBSERVER-5-CONNECTION_FAILED: Switch 1 R0/0: nginx: connection faile
nevermore266
%WEBSERVER-5-CONNECTION_FAILED: Switch 1 R0/0: nginx: connection failed from host 172.12.24.1 - Cipher Mismatch/No shared ciphe with cisco switch
marce1000
              - To which platform (and or model) are you trying to connect ?
 M.
Hellow Guys
You need to delete the certificate "no crypto pki trustpoint TP-self-signed"
and delete all configs about ip http and ip http secure
then config again the ip http and ip http secure and a new certificate signed will be created
the issue is presented when the certificate is old and the explorer is using new certificates
good luck!!
