What could be causing EssentialsDM to be stalled?
Russell Bovaird
Enthusiast
Enthusiast
Good evening all,
I have a problem in which RME is not discovering devices from CS.  It did work until several (52) Microsoft updates were installed and the machine rebooted.
LMS 3.2
CiscoWorks Common  Services 3.3.0
Campus Manager 5.2.1
CiscoView 6.1.9
CiscoWorks  Assistant 1.2.0
Device Fault  Manager 3.2.0
Internetwork Performance  Monitor 4.2.0
LMS Portal 1.2.0
Resource Manager  Essentials 4.3.1
Hardware Details:  Windows 2008 Server  - 4 x Dual Core with 8 Gb memory
The system was working until MS updates were installed:
     kb installations from 16 april 2010.pdf
Now the Essentials DM is waiting to initialize
Showing 1 records
1.
Waiting to initialize.5080004/21/2010 4:51:31 PMNot applicable
Because this EssentialsDm is waiting - there are 11 other processes that have not started:
ProcessState ProcessId ProcessRC ProcessSigNo ProcessStopTime
1.ChangeAuditNever started000N/ANot applicable
2.ConfigMgmtServerNever started000N/ANot applicable
3.CSDiscoveryNever started000N/ANot applicable
4.CTMJrmServerNever started000N/ANot applicable
5.DCRDevicePollNever started000N/ANot applicable
6.FHPurgeTaskNever started000N/ANot applicable
7.ICServerNever started000N/ANot applicable
8.PMCOGSServerNever started000N/ANot applicable
9.RMEOGSServerNever started000N/ANot applicable
10.SyslogAnalyzerNever started000N/ANot applicable
11.UTMajorAcquisitionNever started000N/ANot applicable
I have reinstalled:
     CS, Java, & RME
to no avail.
I have attached EssentialsDM and EssentialsDM_Server for perusal and perhaps some help in resolving this conundrum.
PS: Rolling back the MS updates is not an option.
Any hints/tips?
All help gratefully received...
Russ
Nael Mohammad
Contributor
Contributor
Try the following steps:
1. net stop crmdmgtd
2. Take backup of the following files
       NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/ctmregistry and
       NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/ctmregistry.backup
Note: NMSROOT is the C:\Program Files\CSCOpx directory.
3. Remove the above two files ctmregistry and ctmregistry.backup
4. net start crmdmgtd
Nael Mohammad
Contributor
Contributor
Thank you very much Nael.
It's all working fabulously now.
Just for my reference:
          How did you know that these files were the culprits and what to do with them?
          Did the logs help and which part in particular?
Thanks again.
Kind regards
Russ
The logs provided pointed to a known bug CSCte49301 .
Recognize Your Peers
