what is the minimum temperature for cisco devices
Hello All,
Can anyone tell me exactly what is the minimum temperature for cisco devices, like if the temperature is bellow or equal 4 what will be the impact on the devices “2800/3800/3560/2960/6500E.
Regards.
A temperature threshold is exceeded if any of the following conditions occur:
The internal temperature of the router is over 100° C.
The internal temperature of the AC power supply is over 100° C.
The internal temperature of the DC power supply is over 100° C.
I don't think their is a minimum temperature so as long as the router is not freezing you should be fine.
Cisco advises a minimum of 32°F (0°C)
till now no Answer
thanks bro for the answer
