Wireless LAN Controller- How to Disable DTLS Encryption
cgutierrezc1
Hi everybody.
How to disabled DTLS Control Packets encryption on WLC release 8.6.101.0 or 8.5.120.0 for troubleshooting purposes?
marce1000
                    Step1) Logon to your controller
Step 2 Choose Wireless > Access Points > All APs to open the All APs page.
Step 3 Click the name of the access point for which you want to enable data encryption.
Step 4 Choose the Advanced tab to open the All APs > Details for (Advanced) page (see Figure 8-1).
Figure 8-1 All APs > Details for (Advanced) Page
Step 5 Select the Data Encryption check box to enable data encryption for this access point or unselect it to disable this feature. The default value is unselected.
Thanks for your reply.
The Data Encryption Checkbox involve the Control CAPWAP message? Capwap Data + Capwap Ctrl message?
 - I tend to think it's only capwap-data; but check the document below (read it completely) ; it may clarify this :
https://supportforums.cisco.com/t5/wireless-mobility-documents/capwap-encryption-using-dtls/ta-p/3148917
M.
Thank you, I had already read it. And I also read these other two links:
https://mrncciew.com/2013/03/17/ap-registration/
http://what-when-how.com/deploying-and-troubleshooting-cisco-wireless-lan-controllers/capwap-communication-control-and-data-encryption-cisco-wireless-lan-controllers/
in those links, the authors talk about the command: "test capwap encr APNAME", and that is why I consult if there is an equivalent command in version 8.6 or 8.5...
