wirelles lan controller infromation
Luis Polanco
I ask this because in my work they told me to create some vlan
on the switch I have several vlans created and configured
but i would like to know if i can create vlan
in the wlc without thin access points
and put the port in trunk mode
which is connected to the switch port
balaji.bandi
Not sure we understood the question here, you want to connect WLC or AP to switch?
Either case, the port required to allow VLAN in that port ( or it should be trunk mode)
BB
balaji.bandi
BB
