Wireshark Setup
winston.lewis
Does anyone use wireshark to capture packets, if yes, what are the steps to begin the process? The ports have already been spanned and ready to go.
Please advise....
Joe Clarke
I use it all the time.  It's very easy to use.  Just plug your wireshark host into the destination SPAN port and go to Capture > Start.  That will start capturing all ports spanned from the source.  If you want to do filtering of these packets as the capture is running, go to Capture > Options and define a capture filter.  For example, to filter on all HTTP traffic, use the filter "tcp port 80".
