Wireshark UDP
Kevin18
I am currently working on a simple UDP communication. The client.py and server.py is finished and the result is something like that:
My computer is the server while my Kali Linux (I use a VM) is the client.
I want to analyze this UDP communication but wireshark dont show anything. I use the filter "ip.addr == 192.168.0.11 and udp and ip.addr == 192.168.0.22 and udp" (Those are the IP from the client and server). Wireshark dont show any packet.
But if I take the IP from the client out. Wireshark is working and show the packet. I am very confused. Is it normal that wireshark dont show the IP from a VM. I can ping the IP from the VM. Even the ping doesnt show up in Wireshark.
If u need more information just ask.
12 Replies 12
ip.addr == src <<- not show anything
ip.addr == des <<- show udp traffic
Thank you for the answer. Wireshark list up a bunch of packet. Where can I find the UDP packet for this communication. I am the server and the client(my VM) send me the message "hello".
udp and ip.addr == x.x.x.x
you use wrong filter
I change my IP to 192.168.0.17, the client IP is 192.168.0.11
friend the filter is green meaning it accept by wiresharke
only after you add
udp and ip.addr == x.x.x.x <<- add this then press enter in keyboard, enter will make wiresharke filter the traffic
I dont know if I do it right. First, I go to filter and put "udp and ip.addr == 192.168.0.17" in. After that I press Enter and the result is the same.
udp.port == xx <<- try this way
also
udp.port == xx and ip.addr == x.x.x.x <<- also try this
dont forget press enter in end
Thank you. My problem now is that wireshark cant receive my packet from my VM and they are in the same subnet. But I can ping it and I choose Network Bridge.
You are welcome.
Sorry, I didnt see that. I tried what u suggest and the result remain the same.
it can there is no UDP traffic so check all traffic send receive between two hosts
ip.src== xxx and ip.dst == yyy <<- use this filter
check the output if there is any UDP traffic or not
I did not follow the entire thread, but just make sure that your VM does not use a bridged adapter, but NAT mode. It used t be that Wireshark cannot see any traffic if bridged adapters were being used...not sure if that is still the case.
