Working with TAC on EEM script - failing
cthorsen007
Level 4
Level 4
Never runs.
event manager applet AT958
event timer cron cron-entry "01 13 * * *"
action 0.1 cli command "enable"
action 1.1 cli command "term length 0"
action 1.2 cli command "show clock | append bootflash:AT958.TXT"
action 1.3 cli command "show ip int brief | append bootflash:AT958.TXT"
action 1.4 cli command "show ip eigrp neighbors | append bootflash:AT958.TXT"
action 1.5 cli command "show ip eigrp interfaces | append bootflash:AT958.TXT"
action 2.1 cli command "show ip route | append bootflash:AT958.TXT"
action 2.2 wait 5
action 2.3 cli command "show ip arp | append bootflash:AT958.TXT"
action 2.4 wait 3
action 3.1 cli command "show proc cpu sorted | append bootflash:AT958.TXT"
action 3.2 wait 2
action 3.3 cli command "show proc cpu sorted | append bootflash:AT958.TXT"
action 3.4 wait 2
action 3.5 cli command "show proc cpu sorted | append bootflash:AT958.TXT"
action 3.6 wait 2
action 3.7 cli command "show proc cpu sorted | append bootflash:AT958.TXT"
action 3.8 wait 2
action 4.1 cli command "show tech | append bootflash:AT958.TXT"
action 4.2 wait 20
action 4.3 syslog msg "Finished logging information to file system:AT958.txt..."
Embedded Event Manager Version 3.20
Component Versions:
eem: (v320_backlog)3.0.6
eem-gold: (v320_throttle)1.0.4
eem-call-home: (v320_throttle)1.2.0
Event Detectors:
Name                Version   Node        Type
application         01.00     node3/0     RP
rf                  01.00     node3/0     RP
identity            01.00     node3/0     RP
mat                 01.00     node3/0     RP
neighbor-discovery  01.00     node3/0     RP
routing             03.00     node3/0     RP
syslog              01.00     node3/0     RP
cli                 01.00     node3/0     RP
counter             01.00     node3/0     RP
interface           01.00     node3/0     RP
ioswdsysmon         01.00     node3/0     RP
none                01.00     node3/0     RP
oir                 01.00     node3/0     RP
snmp                01.00     node3/0     RP
timer               01.00     node3/0     RP
snmp-object         01.00     node3/0     RP
snmp-notification   01.00     node3/0     RP
test                01.00     node3/0     RP
config              01.00     node3/0     RP
env                 01.00     node3/0     RP
gold                01.00     node3/0     RP
rpc                 01.00     node3/0     RP
We can get a very basic script to run.
event manager applet TEST
event timer cron cron-entry "19 13 * * *"
action 1.0 syslog msg "EEM is WORKING"
Feb  4 13:19:00.009 PST: %HA_EM-6-LOG: TEST: EEM is WORKING
Vishesh Verma
Hi Chris,
I Tested it and found that it is not the script that is failing. It is the filesystem that is not supporting the appending.
R2#show ip int br | append bootflash://test.txt
% Appending is not supported in this file system
So I tried to use an ftp server to export the data....Just like following and it works. There was just one problem that my ftp server was kind of slow so I had to add action x.y wait after every cli command to capture all the data and sometimes it wouldn't capture all of it.
Check if the platform supports -
R2#show ip int br | redirect bootflash://test.txt          <<          With this we will have to create multiple files it won't append and remove the previous data in the file
R2#show ip int br | tee /apend bootflash://test.txt
action 1.2 cli command "show clock | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 1.3 wait 1
action 1.4 cli command "show ip int brief | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 1.5 wait 2
action 1.6 cli command "show ip eigrp neighbors | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 1.7 wait 2
action 1.8 cli command "show ip eigrp interfaces | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 1.9 wait 2
action 2.1 cli command "show ip route | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 2.2 wait 2
action 2.3 cli command "show ip arp | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 2.4 wait 2
action 3.1 cli command "show proc cpu sorted | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 3.2 wait 2
action 3.3 cli command "show proc cpu sorted | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 3.4 wait 2
action 3.5 cli command "show proc cpu sorted | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 3.6 wait 2
action 3.7 cli command "show proc cpu sorted | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 3.8 wait 2
action 4.1 cli command "show tech | append ftp://test:cisco@172.16.1.1/AT958.txt"
action 4.2 wait 20
Vishesh Verma
And you can use following show commands for verification -
show event manager history events
show event manager statistics policy
- Vishesh
Joe Clarke
This applet will not work as it will timeout before it finishes.  You will need to at least config:
event timer cron cron-entry "01 13 * * *" maxrun 60
On top of that, you may need to configure:
event manager session cli username USER
If you are using command authorization, where USER is a username authorized to run all of these commands.
