Write Memory Changes .bin file
ccallahan26
Visitor
All,
I have a Cisco WS-C4510R+E with WS-X45-SUP8-E using Cisco IOS XE Release 3.10.xE.
Problem: every time i change anything in the config and then write memory it changes my .BIN file.
Example:
Before write memory
73448 -rw- 393246976 Oct 31 2019 14:18:34 -05:00 cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
After write memory
73448 -rw- 22349 Oct 31 2019 14:18:34 -05:00 cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
The big problem is it will not reboot to the changed .BIN file, I have to boot TFTP
Any help would be greatly appreciated.
remove the statement
boot config bootflash:cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
I'm not sure whether or not this is the culprit but it doesn't need to be there.
11 Replies 11
Mark Elsen
 - Check if you have any boot-commands in your config that could affect the BIN filename settings (e.g.). Also check the conf-register settings and check if the  value is as you expect and or needed for production operation.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
this is whats in the config
BOOT variable = bootflash:cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin,1;
CONFIG_FILE variable = bootflash:cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
BOOTLDR variable does not exist
Configuration register is 0xE142
Standby BOOT variable = bootflash:cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin,1;
Standby CONFIG_FILE variable = bootflash:cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
Standby BOOTLDR variable does not exist
Standby Configuration register is 0xE142
here is setup boot parameters and correct conf reg :
change according to the document as suggested :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/24061-149.html
BB
not to make fun of your pain, but after all these years, this is the first time I have seen a config register set to that setting.
anyhow, the guide balaji points you to should take care of matters
that didn't fix the problem:
7445-131B-ITN#sh boo
Standby Configuration register is 0x2102
however
 after wr mem
73442 drwx 4096 Sep 28 2017 10:57:48 -05:00 virtual-instance
73444 drwx 4096 Sep 28 2017 10:57:50 -05:00 virtual-instance-stby-sync
73446 drwx 4096 Sep 28 2017 10:58:52 -05:00 onep
81601 drwx 4096 Oct 26 2019 00:02:54 -05:00 pxe
81603 drwx 4096 Sep 19 2019 22:59:10 -05:00 scripts
73448 -rw- 23875 Nov 1 2019 12:57:08 -05:00 cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
73451 -rw- 1174 Oct 2 2019 23:08:02 -05:00 banner.txt
ccallahan26
Visitor
still change anything in the config and then write memory it changes my .BIN file.
to clarify, you are using "wri me" and not "copy run start"? If so, then there has to be something in the config. Can you send a text file of "sho run all"? you can sanitize it, and you can remove the port configs, won't need to see those.
also, what version of ROMMON are you running?
I honestly have nothing on this one, I have never seen this behavior with any device I've worked with.
thanks
Yes "wr mem"
RommonVer : 15.1(1r)SG5
Current config:
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service compress-config
hostname 7
boot-start-marker
boot system flash bootflash:cat4500es8-universalk9.SPA.03.10.03.E.152-6.E3.bin
boot-end-marker
vrf definition mgmtVrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5
username c secret 5
aaa new-model
aaa group server radius NPS_RADIUS_SERVERS
server-private 10. auth-port 1812 acct-port 1813 key 7
aaa authentication login default group NPS_RADIUS_SERVERS local
aaa authorization console
aaa authorization exec default group NPS_RADIUS_SERVERS local if-authenticated
aaa authorization network default group radius
aaa accounting exec default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
no ip source-route
ip domain-name D
ip name-server 10.
ip dhcp snooping vlan 1-3,5,7-10,26,56,69
no ip bootp server
no ip verify header vlan all
login on-failure log
login on-success log
vtp domain d
vtp mode transparent
key chain RIP_AUTHENTICATION
key 1
key-string 7
key chain Rpassword
key 11
key-string 7
power redundancy-mode redundant
archive
log config
logging enable
logging size 200
notify syslog contenttype plaintext
hidekeys
spanning-tree mode rapid-pvst
no spanning-tree vlan 12
spanning-tree vlan 1-3,10 priority 24576
redundancy
mode sso
main-cpu
auto-sync standard
vlan 2
interface Vlan1
no ip address
shutdown
interface Vlan2
description IT ADMIN VLAN
ip address 10. 255.255.255.0
ip broadcast-address 10.
ip helper-address 10.
interface Vlan10
description Server Vlan
interface Vlan12
description 7445_AP_Control_Subnet
interface Vlan56
description IAAFA Server Vlan - Mike 12/13/12
interface Vlan65
description IAAFA Student Wifi Vlan
ip address 10 255.255.254.0
ip access-group IAAFA_STU-WIFI in
ip access-group IAAFA_STU-WIFI out
ip helper-address 10.0
interface Vlan69
ip address 10 255.255.255.0
interface Vlan131
router eigrp 10
network 10.0.0.0
passive-interface GigabitEthernet1/1
passive-interface GigabitEthernet1/2
eigrp stub connected summary
router rip
version 2
redistribute static metric 1
network 10.
no auto-summary
ip default-gateway 1
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip tcp synwait-time 10
no ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface Loopback0
ip route 0.0.0.0 0.0.0.0 1
ip route 1 255.255.255.0 1
ip ssh time-out 60
ip ssh version 2
ip sla responder
logging history notifications
no logging trap
logging host 1 transport udp port 1338
access-list 1 permit 1 0.0.0.255
access-list 2 permit 1 0.0.0.255
access-list 3 permit 1 0.0.255.255
access-list 4 permit 1 0.0.0.255
access-list 20 remark ACL used to limit SNMP access
access-list 20 permit 1
access-list 25 permit 1 0.0.0.255
access-list 40 remark admin access to switch
access-list 40 permit 1 0.255.255.255 log
access-list 101 permit tcp 1 0.0.0.255 any eq www
access-list 101 permit ip any host 1
snmp-server group dligroup v3 priv access 20
snmp-server view r-mibs iso included
snmp-server location B7445 ITN
snmp-server contact
snmp-server host version 3 priv dligroup
line con 0
session-timeout 10
logging synchronous
stopbits 1
line vty 0 4
session-timeout 10
access-class 40 in
logging synchronous
line vty 5 15
session-timeout 10
access-class 40 in
ntp authenticate
ntp server 10 prefer version 2
end
THANK YOU!
you're welcome
