while trying to activate the licence for my cisco prime server, i needed the PID in order to generate the licence file on Cisco portal
I used the CLI PID "Cisco-VM-SPID" which is wrong, since i had to use the PID dedicated to the GUI interface
Unfortunetly a licence file has been generated, and when i try to use it on my CPI i recieve the following error : Wrong PID in licence file
is there a way to edit the licence and use the right PID which is :
PRIME-NCS-VAPL
Many thanks in advance
A.B.
