04-08-2020 01:26 PM
hello
i have a policy-map
with to class
policy-map CheckBand-BandPerUsr class BandPerUsr police cir 10000000000 class class-default police cir 10000000000
i need to get a (Post Policy Size) by snmp
i look and find a right oid but value was wrong
snmpwalk -v2c -c ABCDED X.X.X.X iso.3.6.1.4.1.9.9.166.1.15.1.1.11 iso.3.6.1.4.1.9.9.166.1.15.1.1.11.1298180580.65536 = Gauge32: 4012315000 iso.3.6.1.4.1.9.9.166.1.15.1.1.11.1298180580.131072 = Gauge32: 376176704
Gauge32: 376176704
and now the traffic for class-default is 4,600 Mbps
sh policy-map target Port-channel7: EFP 1045 Service-policy input: CheckBand-BandPerUsr Class-map: BandPerUsr (match-all) 33378869376 packets, 33153538986508 bytes 5 minute offered rate 4025078000 bps, drop rate 0000 bps Match: access-group name BandPerUsr police: cir 10000000000 bps, bc 33292000 bytes conformed 33374131354 packets, 33148621833696 bytes; actions: transmit exceeded 0 packets, 0 bytes; actions: drop conformed 4025078000 bps, exceeded 0000 bps Class-map: class-default (match-any) 41735372388 packets, 38731449873476 bytes 5 minute offered rate 4665204000 bps, drop rate 0000 bps Match: any police: cir 10000000000 bps, bc 33292000 bytes conformed 41735372388 packets, 38731449873476 bytes; actions: transmit exceeded 0 packets, 0 bytes; actions: drop conformed 4665204000 bps, exceeded 0000 bps
i note something
we the traffic above a 4000 Mbps
i get correct value like 4012315000 after i /1024 / 1024 i get a correct value ( 4012 Mbps)
but when traffics off class-map is above of 4100Mbps
i get uncorrected Gauge32 value wit 9 digt only
04-21-2020 04:36 PM
Hey,
I see you are using the below OID which is 32bit counter based, these OIDs are generally limited to around 4.2G and won't give any values higher than that.
Object | cbQosCMPostPolicyBitRate |
OID | 1.3.6.1.4.1.9.9.166.1.15.1.1.11 |
For this reason there are 64bit versions of these OIDs which basically do the same but can store a higher counter. Give it a try with this one:
Object | cbQosCMPostPolicyBitRate64 |
OID | 1.3.6.1.4.1.9.9.166.1.15.1.1.29 |
04-22-2020 09:48 AM
04-26-2020 07:40 AM
08-23-2021 04:31 AM
same issue happen with my ASR1002-X Router did you found any solution
