XRv9000 netflow
jigojar
HI Genius,
 Can anyone confirm that XRv900 will support the netflow? I am not able to configure the flow under the interface?
Pls suggest.
Mark Elsen
 According to the data sheet  is seem to do so :
 https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-734034.html
M.
Hi Merce,
      Thanks for support
But i could not able to configure the flow under the interface. Pls refer the below mentioned log and suggest.
config details:
RP/0/RP0/CPU0:ios#sh run flow exporter-map
Thu Jul 26 08:18:33.690 UTC
flow exporter-map MPLS
 version ipfix
  options interface-table
  options vrf-table
  options sampler-table
 transport udp 2055
 source Loopback0
 destination 100.65.212.9
RP/0/RP0/CPU0:Jul 26 08:18:39.103 : parser[264]: %MGBL-LIBPARSER-3-ERR_DLL_UNKNOWN_FUNC : Failed to locate function: netflow_pd_perf_traffic_supported in DLL 'libnf_pd_verify.dll'
RP/0/RP0/CPU0:ios#sh run flow monitor-map
Thu Jul 26 08:18:39.940 UTC
flow monitor-map MPLS
 record datalinksectiondump
 exporter MPLS
RP/0/RP0/CPU0:ios#sh run sampler-map
Thu Jul 26 08:18:46.812 UTC
sampler-map MPLS
 random 1 out-of 1
RP/0/RP0/CPU0:ios#show ospf neighbor
Thu Jul 26 08:18:54.398 UTC
* Indicates MADJ interface
# Indicates Neighbor awaiting BFD session up
Neighbors for OSPF 1
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.10.50.6      1     FULL/  -        00:00:32    10.10.60.37     GigabitEthernet0/0/0/0
    Neighbor is up for 16:01:52
Total neighbor count: 1
RP/0/RP0/CPU0:ios#conf t
Thu Jul 26 08:18:56.666 UTC
int RP/0/RP0/CPU0:ios(config)#int GigabitEthernet0/0/0/0
RP/0/RP0/CPU0:ios(config-if)#flow ?
  bidirectional  Enable both sending and receiving of flow control pause frames
  egress         Enable the receiving of flow control pause frames
  ingress        Enable the sending of flow control pause frames
RP/0/RP0/CPU0:ios(config-if)#flow egress ?
  <cr>
RP/0/RP0/CPU0:ios(config-if)#flow-control ?
RP/0/RP0/CPU0:ios(config-if)#flow-control egress ?
  <cr>
RP/0/RP0/CPU0:ios(config-if)#show platfo
% Invalid input detected at '^' marker.
RP/0/RP0/CPU0:ios(config-if)#do show platform
Thu Jul 26 08:19:30.263 UTC
Node              Type                       State             Config state
0/0/CPU0          R-IOSXRV9000-LC-C          IOS XR RUN        NSHUT
0/RP0/CPU0        R-IOSXRV9000-RP-C(Active)  IOS XR RUN        NSHUT
 - I am worried about the first exotic error message; could be a software bug ; possibly apply more recent  software releases on your device.
M.
Hi Merce,
  I am using the version 6.2.3. Can you pls suggest which version will support the netflow.
