ARP problem with PIX 515
MAHABUB ALAM
Here is our current layout.
MSR 8540 - CAT5000 - PIX 525 - CAT2950 - HOSTS
I have replaced the PIX 525 from the picture with a PIX 515 with exactly the same config. After I have repalced the firewall, everything went fine except some internal hosts cant ping each other. All the hosts are accessible from the outside. But when I try to ping from one of the internal host to another internal host it times out. After A close look at the ARP entry of the host where I am trying to ping from, I found that it has the same MAC address for the internal interface of the PIX as the MAC address of the host that I am trying to ping. If I put a static arp entry it works. But ofcourse as soon as I reboot the host, I cant ping and it has the same entry in the ARP cache.
I tried clearing the ARP entry in the PIX 515, but still dont work.
Any suggestions?
Here is a copy of the ARP entries:
Interface: 192.168.3.9 on Interface 2
Internet Address Physical Address Type
192.168.3.1 00-50-54-ff-5e-5f dynamic
192.168.3.10 00-50-54-ff-5e-5f dynamic
192.168.3.26 00-50-54-ff-5e-5f dynamic
192.168.3.1 is the address of the internal interface of the pix.
aacole
Level 5
Level 5
Try disable proxy arp on the inside interface,
[no] sysopt noproxyarp
I had a similar problem, this resolved it.
Hello: thanks for your reply. That did the trick. THanks so much again.
