ASA 5505 loses connection every 4 hrs due to Arp issue (Sonic.net flexlink)
stevechege
We have a 5/5 (Flexlink) connection from Sonic.net on a Adtran NetVsta 832 gateway.
We have recently upgraded the firewall on this connection from a PIX515E to a ASA 5505 (ASA 5505 Security Plus license).
I have had issues with ARP on this connction where if i swapped the firewall, i had to call them to clear the ARP on the "ISP" side for the connection to work. That used to work with PIX, but not with ASA firewalls.
The connection drops every 4 hours for a min or so (When i had  ASA Version 8.2(5)) installed , which i suspect is when the ARP times out on the ISP side. I have tested the some configuration on a different WAN connction and it seem ok. So i have norrowed this issue down to an ISP ARP issue and as always when i call... they tell me that the connction is fine on their end.
I have gone back to using the PIX for now .
My questestion is how do i make the ASA to behave the same as the PIX when answering ARP requests. When i upgraded to ASA Version 9.1(3)2, i cannot even get a connection to the internet.
I have tried
no arp permit-nonconnected
arp timeout 14400
arp timeout  800
no joy.
Any suggetions
ASA Version 9.1(3)2
hostname XXXXXXXXXXXX
domain-name XXXXXXXXXXXX
enable password XXXXXXXXXXXX encrypted
passwd XXXXXXXXXXXX encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
description VoIP-LAN
nameif inside
security-level 100
ip address 192.168.1.x 255.255.255.0
interface Vlan2
description WAN Connection
nameif outside
security-level 0
ip address XXXXXXXXXXXX 255.255.255.x
boot system disk0:/asa913-2-k8.bin
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns server-group DefaultDNS
object network inside1
subnet 192.168.1.0 255.255.255.0
object network VoIP-SRVR
host 192.168.1.x
object network VoIP-NOC
host 192.168.1.x
object network VoIP-TEST-SRVR
host 192.168.1.x
object network VoIP-WEB-SRVR
host 192.168.1.x
object-group network Bad-guys-blocked-ips
network-object 41.0.0.0 255.0.0.0
network-object 58.0.0.0 255.0.0.0
network-object 59.0.0.0 255.0.0.0
network-object 102.0.0.0 255.0.0.0
network-object 105.0.0.0 255.0.0.0
network-object 154.0.0.0 255.0.0.0
network-object 157.0.0.0 255.0.0.0
network-object 177.0.0.0 255.0.0.0
network-object 179.0.0.0 255.0.0.0
network-object 181.0.0.0 255.0.0.0
network-object 183.0.0.0 255.0.0.0
network-object 184.106.0.0 255.255.0.0
network-object 186.0.0.0 255.0.0.0
network-object 187.0.0.0 255.0.0.0
network-object 188.0.0.0 255.0.0.0
network-object 189.0.0.0 255.0.0.0
network-object 190.0.0.0 255.0.0.0
network-object 191.0.0.0 255.0.0.0
network-object 196.0.0.0 255.0.0.0
network-object 200.0.0.0 255.0.0.0
network-object 201.0.0.0 255.0.0.0
network-object 220.0.0.0 255.0.0.0
object-group service VOIP-SIP-PORTS
description VOIP SIP ports Cisco Phones
service-object udp destination range 50000 52000
service-object udp destination range sip 5061
object-group service VOIP-RTP-PORTS
description VoIP-RTP-Media-Start/Stop-Port-Range
service-object udp destination range 10000 20000
object-group service VoIP-Srvr-access-PORTS
description Access to VoIP server Services
service-object tcp destination eq www
service-object tcp destination eq https
service-object udp destination eq tftp
service-object tcp destination eq 4445
service-object udp destination eq ntp
object-group service Web-Srvr-access-PORTS
description Access to Web server Services
service-object tcp destination eq 8081
object-group network HQ-Office
network-object XXXXXXXXXXXX 255.255.255.x
object-group network remote-offices
network-object host XXXXXXXXXXXX
object-group network VOIP-PROVIDERS
description VOIP-SERVICE-PROVIDERS Networks
access-list world extended deny ip object-group Bad-guys-blocked-ips any
access-list world extended permit ip object-group HQ-Office any
access-list world extended permit tcp host XXXXXXXXXXXX host 192.168.1.X eq ssh
access-list world extended permit object-group VOIP-RTP-PORTS any host 192.168.1.x
access-list world extended permit object-group VOIP-SIP-PORTS object-group remote-offices host 192.168.1.x
access-list world extended permit object-group VOIP-SIP-PORTS object-group VOIP-PROVIDERS host 192.168.1.x
access-list world extended permit object-group VoIP-Srvr-access-PORTS object-group remote-offices host 192.168.1.x
access-list world extended permit object-group Web-Srvr-access-PORTS object-group remote-offices host 192.168.1.x
access-list world extended permit icmp object-group remote-offices host 192.168.1.x
access-list world extended permit icmp host XXXXXXXXXXXX host 192.168.1.x
access-list world extended permit icmp any any echo-reply
access-list world extended permit icmp any any source-quench
access-list world extended permit icmp any any unreachable
access-list world extended permit icmp any any time-exceeded
pager lines 24
logging enable
logging trap informational
logging asdm informational
logging host inside 192.168.1.x format emblem
mtu inside 1500
mtu outside 1500
ip verify reverse-path interface inside
ip verify reverse-path interface outside
ip audit name OUTSIDE_ATTACK attack action alarm drop
ip audit name OUTSIDE_INFO info action alarm
ip audit name INSIDE_ATTACK attack action alarm drop reset
ip audit name INSIDE_INFO info action alarm
ip audit interface inside INSIDE_INFO
ip audit interface inside INSIDE_ATTACK
ip audit interface outside OUTSIDE_INFO
ip audit interface outside OUTSIDE_ATTACK
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
nat (any,outside) dynamic interface
nat (inside,outside) static XXXXXXXXXXXX
access-group world in interface outside
route outside 0.0.0.0 0.0.0.0 XXXXXXXXXXXX 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 192.168.1.0 255.255.255.255 inside
ssh timeout 30
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.168.1.x source inside
username XXXXXXXXXXXX password XXXXXXXXXXXX encrypted privilege 15
class-map Voice
match dscp ef
class-map inspection_tftp
match default-inspection-traffic
class-map class_sip_udp
match port udp eq sip
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
policy-map Voicepolicy
class Voice
  priority
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:1eefa1df35e9273021ad5760e7e272b0
: end
2 Accepted Solutions
jumora
Level 7
Level 7
First that ASA 5505 uses switch ports so you need to be careful as all interfaces have the same MAC address, then if the ARP table has no problems with the PIX 515 just copy the MAC addresses associated to the WAN and LAN side a virtualize them on to the 5505 with the "mac-address" command within each VLAN defined interface.
Setup a syslog server internally so it can capture at debugging level to see what it reports.
Value our effort and rate the assistance!
enable
config t
logging on
logigng trap 7
logging debug-trace
logging host inside
debug ARP
As you can see I put a debug ARP so that way with the logging debug-trace we can forward ARP debugs to the syslog server.
8 Replies 8
jumora
Level 7
Level 7
Good suggestion on a syslog server, i will setup one and set the logs to "debug level" to see what is going on. It really hard sometime to see the issue be cause it happenes only for 1 min very 4 hours or so ...so the Log server will help.
malshbou
Hi Stephen,
To investigate the root cause of the problem i would setup ARP captures and debugs at the time of the ARP timeout:
capture ARP ethernet-type arp interface outside
debug arp
When the ARP entry is about to expire in the ASA you should see ARP request(WHO-HAS) sent from the ASA asking about the gateway.
However, if there is some problem in the gateway to relearn the ASA's ARP entry after expiry, then it would be good to try reducing the ASA's timeout value to less than the router's one (e.g. to 3 hour) so that the ASA's ARP request after 3 hours refreshes the router's ARP entry (router should IP-MAC learn from source addresses of ARP Request).
Hope this helps.
Mashal Shboul
------------------ Mashal Shboul
Hello Mashal,
I will try your suggestion today. Thanks for the reply. I wll let you know how it goes.
enable
config t
logging on
logigng trap 7
logging debug-trace
logging host inside
debug ARP
I am currently testing your first suggestion of assigning “virtual” MACs to the Vlan interfaces.
I did that last night and so far the connection has not timed out.
So far so good
Crossing my fingers !!!
I will test it for a while before I place the ASA in production on this connection.
You are very correct in saying that the ASA and PIX handle MAC address differently, which makes sense since the ASA uses essentially “a switch” with VLANS for the various interfaces…I.E. INSIDE, OUTSIDE and DMZ.
The problem was that Sonic.net Flexlink Ethernet WAN is very picky about MAC addresses. I think the router on the other end (ISP) side was not getting a MAC address every time it querried our ASA firewall was was getting confused and thus before the router “learned” the new MAC address, it would stop forwarding packets to us, causing the 1 min downtime every 4hour ( the ARP timeout time- arp timeout 14400).Strange...still a theory.
The ASA assigns MAC addresses sequentially as show below when you do a show interface command.
I have edited the output and altered some MAC address information but you get the idea.
Show interface
MAC address 6c4X.6aXX.cb94 port 0
MAC address 6c4X.6aXX.cb95  port 1
MAC address 6c4X.6aXX.cb96 port 2
MAC address 6c4X.6aXX.cb97  port 3
MAC address 6c4X.6aXX.cb98  port 4
MAC address 6c4X.6aXX.cb99  port 5
MAC address 6c4X.6aXX.cb9a  port 6
MAC address 6c4X.6aXX.cb9b  port 7
Interface Vlan1 "inside"  MAC address 6c4X.6aXX.cb9c
Interface Vlan2 "outside" MAC address 6c4X.6aXX.cb9c
The strange part is that the ASA assigns the same MAC address for the “inside and “Outside” Vlan interaces see below.
What I have done is to assign the “outside” vlan interface the next sequential MAC address
I.E
mac-address 6c4X.6aXX.cb9d
From
Interface Vlan1 "inside", is up, line protocol is up
  Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
        MAC address 6c4X.6aXX.cb9c, MTU 1500
        IP address 192.168.1.X, subnet mask 255.255.255.0
  Traffic Statistics for "inside":
        11340 packets input, 658281 bytes
        89801 packets output, 11522641 bytes
        1852 packets dropped
      1 minute input rate 0 pkts/sec,  4 bytes/sec
      1 minute output rate 0 pkts/sec,  81 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  10 bytes/sec
      5 minute output rate 1 pkts/sec,  169 bytes/sec
      5 minute drop rate, 0 pkts/sec
Interface Vlan2 "outside", is up, line protocol is up
        IP address XXX.XXX.XXX.XXX, subnet mask 255.255.255.240
  Traffic Statistics for "outside":
        22933 packets input, 1441961 bytes
        8495 packets output, 713252 bytes
        10352 packets dropped
      1 minute input rate 0 pkts/sec,  11 bytes/sec
      1 minute output rate 0 pkts/sec,  1 bytes/sec
      5 minute input rate 0 pkts/sec,  24 bytes/sec
      5 minute output rate 0 pkts/sec,  9 bytes/sec
to
        MAC address 6c4X.6aXX.cb9d, MTU 1500
result
show run
interface Vlan2
nameif outside
security-level 0
ip address XXX.XXX.XXX.XXX 255.255.255.XXX
I will keep you posted on how it goes
Thanks guys, it looks like that was the solution as Jumora suggested.
interface Vlan2
nameif outside
security-level 0
The issue is with how the ASA handles MAC-Addresses as compared to a PIX. Some internet gateways/routers do not play nice with the ASA. The connection drops every 4hours or so as in my case when arp timesout on the WAN side. The fix is to nail down a "static" mac address to the virual Vlan associated to the problematic port in this case the WAN connection to the Sonic.net Flexlink ethernet  no a Adtran NetVsta 832 gateway.
For a week or so  i got yelled at for "dropped calls" glad this is resolved...lol...off to the next fire.
Thank you for letting us help, please rate all who assisted on the ticket!!!!!
