ASA and slow connection port 80 - http
martinjina_2
Hi all,
I have problem with connection ASA 8.3.1
web_server1 port 80 (inside_in1,Sec.Level 100,vlan1) <--- ASA5550 (1Gb)---> (Sec.Level 100,inside_in2,vlan2) web_client dynamic port (wget)
wget (linux web tools) have speed 150KB/s. This is verry low.
Inspect mod is OFF
Migrate port 80 on 1080. It's OK, speed is  cca 70MB/s (1Gb network).
Ssh speed cca 25 MB/s.
Please help, thanks.
Best regards,
Martin
Configuration:
class-map priority-class
  match port tcp eq 1080
class-map inspection_default
  match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
  parameters
    message-length maximum 512
policy-map type inspect esmtp esmtp_map
  parameters
    no mask-banner
    allow-tls action log
policy-map global_policy
  class inspection_default
    inspect h323 h225
    inspect h323 ras
    inspect rsh
    inspect rtsp
    inspect skinny
    inspect sunrpc
    inspect xdmcp
    inspect sip
    inspect netbios
    inspect tftp
    inspect ip-options
    inspect ftp
policy-map qos_policy
  class priority-class
    police output 900000000 45000
   inspect http
   police input 900000000 45000
service-policy global_policy global
service-policy qos_policy interface inside_1
Nagaraja Thanthry
I see that in your configuration, you are inspecting HTTP traffic. Can you turn it off?
   no inspect http
Hope this helps.
NT
this inspect is for port 1080.
I try
no inspect http
in
Unfortunately, no results. Speed is low.
I'm using the routing between vlan1 and vlan2
Thanks for your response
MJ
