Bulk Import on 1010 using FDM
mumbles202
Level 5
Level 5
Migrating to a 1010 running FDM and running into an issue w/ an ip list that's grown to over 200 entries that needs to be carried over.  When running FMC you can upload the contents of a text file or at least copy/paste multiple items into an object-group pretty easily, but I haven't found any such way to do that when running FDM.  Is it possible at all to do this, even if I have to use API calls in order to accomplish it?
engineer467
did you find a way to do it in fdm? i am also struggling
@engineer467 yes you can bulk import network objects to FDM, but you'll have to create a python script and import from CSV. If you open the API explorer from within the FDM console, scroll to the "NetworkObject", this will provide more information.
engineer467
Thank you Rob, I did go through it, but it all went above my head since i do not know python. have to start learning python now. lol
