Hi all
unfortunately in boatloader of CIDS ( which is plugged in my 2600 ) i configured in config command the Secondary partition to use ...... now i want to reimage my sensor but whenever i reset the sensor in order to reimage it its not boot up from normal boatloader server prompt .... its seems like its looking for bootloader image as its give some tftp feature's....etc.
please let me know how i can revert boatloader config to use primary partition again so it will give me normal boatloader prompt.
its very urgent as its become question of my job, please let me know the solution as soon as possible i will be very thankful to you.
Zeshan
Solved! Go to Solution.
Zeshan,
Perhaps the following URL will help you out: https://supportforums.cisco.com/docs/DOC-16288
Hi Zeshan,
The steps in this link should help.
Paps
Zeshan,
