I think it depends how you want to configure your failover sceanrio. By default, only physical interfaces are monitored automatically, so you will need to enable the monitoring on each of those virtual sub-interfaces. you can configure sub-interfaces monitored too, so you know if there's a layer-2 issue with the switch(es) your ASAs are uplinked to.
however, if you already monitoring the individual interface in case if these physical interface fail your ASA will failover to other unit. now if there is a blip on one of the sub-interface (false flag) than your active unit will failover to standby and standby will become active.
please do not forget to rate.
