Failed to block SIP traffic using ACL on ASA
Hamdi Kadri
I have trouble blocking SIP traffic that crosses my ASA appliances in both HQ (ASA 5515-X) and Branch (ASA 5510) offices :
The goal is to block all traffic from the IP-Phone 10.1.16.7 to the CUCM1 Subscriber 192.168.150.2 which will make it register with the CUCM2 Subscriber 192.168.156.1.
When I apply the ACL though, traffic still passes through the Branch ASA !
access-list inside_access_in line 1 extended deny ip host 10.1.16.7 host 192.168.150.2
access-group inside_access_in in interface inside
I tried to block the traffic using the HQ ASA and it didn't work either.
Is there something that I am missing while trying this configuration?
ASA version: Branch 9.1(4) & HQ 9.6(2)
UPDATE: I was able to block the traffic using an extended ACL in my LAN Switch.
It could be that the ASA already had an existing connection for the traffic after you applied the ACL entry for that phone. Due to order of operations for ASA, if there was an existing connection for that flow the ACL check is skipped. Might be an idea to clear any connections on the ASA for tha phone IP then test.
11 Replies 11
GRANT3779
It might help to see the config of the Branch ASA.
One thing to note also is that if you want to block access to only that server you should add another line on your ACL (at end) allowing all other traffic otherwise you will block everything (if applied properly) as there will be an implicit deny at end of ACL.
Thanks @GRANT3779, the implicit "permit ip any any" is configured already and I have no trouble with that.
Good, can we see output of
sh access-list
and
sh run access-group
What Interfaces are all configured on the ASA?
Sorry for the long output. Notice that the ACL in question is the first one applied to the inside interface. Yet SIP traffic is not dropped to 192.168.150.2
ASA# sh access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
            alert-interval 300
access-list inside_access_in; 50 elements; name hash: 0x433a1af1
access-list inside_access_in line 1 extended deny ip host 10.1.16.7 host 192.168.150.2 (hitcnt=14) (inactive) 0x9cca6348
access-list inside_access_in line 2 extended permit object-group DM_INLINE_PROTOCOL_1 object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6 (hitcnt=34945) 0x0b9bf62f
  access-list inside_access_in line 2 extended permit ip 10.1.11.0 255.255.255.0 host 213.186.33.20 (hitcnt=22551) 0xa4030b93
  access-list inside_access_in line 2 extended permit ip 10.1.11.0 255.255.255.0 host 196.203.145.246 (hitcnt=12122) 0x1e6e399a
  access-list inside_access_in line 2 extended permit ip 10.1.12.0 255.255.255.0 host 213.186.33.20 (hitcnt=208) 0x06a9a1e7
  access-list inside_access_in line 2 extended permit ip 10.1.12.0 255.255.255.0 host 196.203.145.246 (hitcnt=0) 0x312bbdff
  access-list inside_access_in line 2 extended permit icmp 10.1.11.0 255.255.255.0 host 213.186.33.20 (hitcnt=0) 0xed9093c1
  access-list inside_access_in line 2 extended permit icmp 10.1.11.0 255.255.255.0 host 196.203.145.246 (hitcnt=0) 0xb1092ca9
  access-list inside_access_in line 2 extended permit icmp 10.1.12.0 255.255.255.0 host 213.186.33.20 (hitcnt=0) 0x154d2d39
  access-list inside_access_in line 2 extended permit icmp 10.1.12.0 255.255.255.0 host 196.203.145.246 (hitcnt=0) 0x28ee83d8
  access-list inside_access_in line 2 extended permit ip 10.1.11.0 255.255.255.0 host 169.255.68.36 (hitcnt=64) 0x990182fe
  access-list inside_access_in line 2 extended permit ip 10.1.12.0 255.255.255.0 host 169.255.68.36 (hitcnt=0) 0xbe205c35
  access-list inside_access_in line 2 extended permit icmp 10.1.11.0 255.255.255.0 host 169.255.68.36 (hitcnt=0) 0xe003ea90
  access-list inside_access_in line 2 extended permit icmp 10.1.12.0 255.255.255.0 host 169.255.68.36 (hitcnt=0) 0x64e9164e
access-list inside_access_in line 3 extended permit ip object Stagiaires-Annexe object-group DM_INLINE_NETWORK_3 (hitcnt=0) 0x33d3f6d4
  access-list inside_access_in line 3 extended permit ip 10.1.18.0 255.255.255.0 host 192.168.51.254 (hitcnt=0) 0xfe7515f6
  access-list inside_access_in line 3 extended permit ip 10.1.18.0 255.255.255.0 host 192.168.66.46 (hitcnt=0) 0x8512f122
  access-list inside_access_in line 3 extended permit ip 10.1.18.0 255.255.255.0 host 192.168.1.254 (hitcnt=0) 0x30184d0c
access-list inside_access_in line 4 extended deny ip object Stagiaires-Annexe object-group DM_INLINE_NETWORK_9 (hitcnt=0) 0xd712d2b6
  access-list inside_access_in line 4 extended deny ip 10.1.18.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=0) 0xce112e71
  access-list inside_access_in line 4 extended deny ip 10.1.18.0 255.255.255.0 172.16.0.0 255.240.0.0 (hitcnt=0) 0xc4e7471e
  access-list inside_access_in line 4 extended deny ip 10.1.18.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=0) 0xaae7fae2
access-list inside_access_in line 5 extended permit ip object Stagiaires-Annexe any (hitcnt=0) 0x2856050e
  access-list inside_access_in line 5 extended permit ip 10.1.18.0 255.255.255.0 any (hitcnt=0) 0x2856050e
access-list inside_access_in line 6 extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_13 (hitcnt=110875440) 0x76b16f78
  access-list inside_access_in line 6 extended permit ip 10.1.11.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=2024) 0xbe15fe21
  access-list inside_access_in line 6 extended permit ip 10.1.11.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=1962541) 0x35278d2e
  access-list inside_access_in line 6 extended permit ip 10.1.11.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=48974129) 0x30694537
  access-list inside_access_in line 6 extended permit ip 10.1.14.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=0) 0x83e4b91c
  access-list inside_access_in line 6 extended permit ip 10.1.14.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=384) 0xa799fc8b
  access-list inside_access_in line 6 extended permit ip 10.1.14.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=792691) 0xc74b52d1
  access-list inside_access_in line 6 extended permit ip 10.1.17.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=8600) 0x8db602c2
  access-list inside_access_in line 6 extended permit ip 10.1.17.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=2695202) 0x26f9363c
  access-list inside_access_in line 6 extended permit ip 10.1.17.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=20044188) 0x5ccb45fe
  access-list inside_access_in line 6 extended permit ip 10.1.15.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=2) 0x1d3e79cb
  access-list inside_access_in line 6 extended permit ip 10.1.15.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=54) 0x5441d112
  access-list inside_access_in line 6 extended permit ip 10.1.15.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=41535) 0x04887959
  access-list inside_access_in line 6 extended permit ip 10.1.13.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=0) 0x95cdbdff
  access-list inside_access_in line 6 extended permit ip 10.1.13.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=234) 0x638ad29c
  access-list inside_access_in line 6 extended permit ip 10.1.13.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=3365413) 0x8b673be9
  access-list inside_access_in line 6 extended permit ip 10.1.12.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=11) 0x2d48f623
  access-list inside_access_in line 6 extended permit ip 10.1.12.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=248017) 0x0822d55a
  access-list inside_access_in line 6 extended permit ip 10.1.12.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=28016714) 0x953638c3
  access-list inside_access_in line 6 extended permit ip 10.1.16.0 255.255.255.0 172.16.15.0 255.255.255.0 (hitcnt=1166) 0xdff454dc
  access-list inside_access_in line 6 extended permit ip 10.1.16.0 255.255.255.0 10.0.0.0 255.0.0.0 (hitcnt=54644) 0xdf0a50ec
  access-list inside_access_in line 6 extended permit ip 10.1.16.0 255.255.255.0 192.168.0.0 255.255.0.0 (hitcnt=4667891) 0x290c00dc
access-list inside_access_in line 7 extended permit ip object Admin-Annexe object Infra-WAN (hitcnt=6375) 0x1d83cbfc
  access-list inside_access_in line 7 extended permit ip 10.1.11.0 255.255.255.0 172.16.0.0 255.240.0.0 (hitcnt=6375) 0x1d83cbfc
access-list inside_access_in line 8 extended permit ip object Internet-Guest-Annexe any (hitcnt=6446725) 0x17e3d7cb
  access-list inside_access_in line 8 extended permit ip 10.1.17.0 255.255.255.0 any (hitcnt=6446725) 0x17e3d7cb
access-list inside_access_in line 9 extended permit ip 10.1.11.0 255.255.255.0 host 5.5.5.1 (hitcnt=125) 0x52a2ee1d
access-list inside_access_in line 10 extended permit ip object-group DM_INLINE_NETWORK_4 172.16.0.0 255.240.0.0 (hitcnt=0) 0x01e74645
  access-list inside_access_in line 10 extended permit ip host 10.1.11.1 172.16.0.0 255.240.0.0 (hitcnt=0) 0x4c7afb74
  access-list inside_access_in line 10 extended permit ip host 10.1.11.2 172.16.0.0 255.240.0.0 (hitcnt=0) 0x43ae0660
access-list inside_access_in line 11 extended permit ip object-group DM_INLINE_NETWORK_14 any (hitcnt=107829) 0x341cad0c
  access-list inside_access_in line 11 extended permit ip host 10.1.11.10 any (hitcnt=26790) 0x6a6bac63
  access-list inside_access_in line 11 extended permit ip host 10.1.11.1 any (hitcnt=73150) 0x751f0645
  access-list inside_access_in line 11 extended permit ip host 10.1.11.183 any (hitcnt=7889) 0x45d2ae65
access-list inside_access_in line 12 extended permit ip any any (hitcnt=13289) 0xa925365e
access-list outside_access_in; 24 elements; name hash: 0x6892a938
access-list outside_access_in line 1 extended deny object-group TCPUDP host 192.168.150.2 host 10.1.16.7 eq sip inactive (hitcnt=0) (inactive) 0x865a7845
  access-list outside_access_in line 1 extended deny udp host 192.168.150.2 host 10.1.16.7 eq sip inactive (hitcnt=0) (inactive) 0x4dc05507
  access-list outside_access_in line 1 extended deny tcp host 192.168.150.2 host 10.1.16.7 eq sip inactive (hitcnt=0) (inactive) 0xa50dc3d7
access-list outside_access_in line 2 extended permit ip object-group DM_INLINE_NETWORK_11 object-group DM_INLINE_NETWORK_2 (hitcnt=32152489) 0xebd09fbf
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.11.0 255.255.255.0 (hitcnt=785) 0xf711f91d
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.14.0 255.255.255.0 (hitcnt=1120) 0x0fe9ec1b
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.17.0 255.255.255.0 (hitcnt=2781) 0x7d999bd7
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.15.0 255.255.255.0 (hitcnt=3) 0x7be0b6c7
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.13.0 255.255.255.0 (hitcnt=0) 0xe5a3ecf9
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.12.0 255.255.255.0 (hitcnt=81) 0xb560da4f
  access-list outside_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.16.0 255.255.255.0 (hitcnt=1106) 0x58b226bf
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.11.0 255.255.255.0 (hitcnt=1831669) 0x5a993778
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.14.0 255.255.255.0 (hitcnt=2257) 0x4faf90c7
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.17.0 255.255.255.0 (hitcnt=488229) 0xe8018521
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.15.0 255.255.255.0 (hitcnt=510) 0xca476dd5
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.13.0 255.255.255.0 (hitcnt=596) 0xa1037fbf
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.12.0 255.255.255.0 (hitcnt=21408) 0xcf765b03
  access-list outside_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.16.0 255.255.255.0 (hitcnt=29652) 0xa840a04c
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.11.0 255.255.255.0 (hitcnt=23560603) 0xf49d924f
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.14.0 255.255.255.0 (hitcnt=504760) 0x9ab61939
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.17.0 255.255.255.0 (hitcnt=1432644) 0x86752b20
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.15.0 255.255.255.0 (hitcnt=133040) 0x8d7c6a2b
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.13.0 255.255.255.0 (hitcnt=2061311) 0x79a64ae5
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.12.0 255.255.255.0 (hitcnt=2006582) 0x0037cfab
  access-list outside_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.16.0 255.255.255.0 (hitcnt=73353) 0x1f6662a3
access-list outside_access_in line 3 extended permit ip object Infra-WAN object Admin-Annexe (hitcnt=576182) 0x9e19c570
  access-list outside_access_in line 3 extended permit ip 172.16.0.0 255.240.0.0 10.1.11.0 255.255.255.0 (hitcnt=576182) 0x9e19c570
access-list internet_access_in; 5 elements; name hash: 0x463c69d2
access-list internet_access_in line 1 extended permit icmp any any (hitcnt=646225) 0x637a0ab4
access-list internet_access_in line 2 extended permit ip object-group DM_INLINE_NETWORK_7 object-group DM_INLINE_NETWORK_8 (hitcnt=91) 0x3f274fb9
  access-list internet_access_in line 2 extended permit ip host 213.186.33.20 10.1.11.0 255.255.255.0 (hitcnt=82) 0x0aabb91e
  access-list internet_access_in line 2 extended permit ip host 213.186.33.20 10.1.12.0 255.255.255.0 (hitcnt=1) 0x2885eeeb
  access-list internet_access_in line 2 extended permit ip host 196.203.145.246 10.1.11.0 255.255.255.0 (hitcnt=8) 0xb5f545de
  access-list internet_access_in line 2 extended permit ip host 196.203.145.246 10.1.12.0 255.255.255.0 (hitcnt=0) 0x412b1331
access-list outside2_access_in; 24 elements; name hash: 0x6ab55d5f
access-list outside2_access_in line 1 extended deny object-group TCPUDP host 192.168.150.2 host 10.1.16.7 eq sip inactive (hitcnt=0) (inactive) 0x8ee519f3
  access-list outside2_access_in line 1 extended deny udp host 192.168.150.2 host 10.1.16.7 eq sip inactive (hitcnt=0) (inactive) 0xdaf9f39e
  access-list outside2_access_in line 1 extended deny tcp host 192.168.150.2 host 10.1.16.7 eq sip inactive (hitcnt=0) (inactive) 0x892950d7
access-list outside2_access_in line 2 extended permit ip object-group DM_INLINE_NETWORK_10 object-group DM_INLINE_NETWORK_12 (hitcnt=367897) 0x33d4ecb3
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.11.0 255.255.255.0 (hitcnt=0) 0xc196fdd3
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.14.0 255.255.255.0 (hitcnt=0) 0xb7cea677
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.17.0 255.255.255.0 (hitcnt=0) 0x9ec867c1
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.15.0 255.255.255.0 (hitcnt=0) 0xf2e2ee68
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.13.0 255.255.255.0 (hitcnt=0) 0x8dd7198c
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.12.0 255.255.255.0 (hitcnt=0) 0x18e273b3
  access-list outside2_access_in line 2 extended permit ip 172.16.15.0 255.255.255.0 10.1.16.0 255.255.255.0 (hitcnt=0) 0xa24b68fb
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.11.0 255.255.255.0 (hitcnt=100914) 0x0c9f3d6a
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.14.0 255.255.255.0 (hitcnt=216) 0x38e70b42
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.17.0 255.255.255.0 (hitcnt=41823) 0x06a4ce4b
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.15.0 255.255.255.0 (hitcnt=0) 0xea595bc0
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.13.0 255.255.255.0 (hitcnt=121) 0x8aa884a9
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.12.0 255.255.255.0 (hitcnt=142928) 0x211682db
  access-list outside2_access_in line 2 extended permit ip 10.0.0.0 255.0.0.0 10.1.16.0 255.255.255.0 (hitcnt=707) 0x0a0a3b24
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.11.0 255.255.255.0 (hitcnt=60003) 0xd7877bf4
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.14.0 255.255.255.0 (hitcnt=806) 0xd5552cf5
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.17.0 255.255.255.0 (hitcnt=4616) 0x5e9a85a3
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.15.0 255.255.255.0 (hitcnt=228) 0x91524a60
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.13.0 255.255.255.0 (hitcnt=408) 0x859e5f61
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.12.0 255.255.255.0 (hitcnt=9579) 0xb4c55cf0
  access-list outside2_access_in line 2 extended permit ip 192.168.0.0 255.255.0.0 10.1.16.0 255.255.255.0 (hitcnt=5548) 0xe2f594db
access-list outside2_access_in line 3 extended permit ip object Infra-WAN object Admin-Annexe (hitcnt=210) 0x77473a8e
  access-list outside2_access_in line 3 extended permit ip 172.16.0.0 255.240.0.0 10.1.11.0 255.255.255.0 (hitcnt=210) 0x77473a8e
ASA#   sh run access-group
access-group outside_access_in in interface outside
access-group internet_access_in in interface internet
access-group outside2_access_in in interface outside2
ASA#
It looks like the specific ACL line for your SIP traffic is set to inactive / disabled.
I am aware of that, I set it inactive after the test failed.
What makes you think that SIP traffic is getting through to CUCM1?
Is it maybe hitting CUCM2 first and then being routed back over the WAN to CUCM1?
I am sure of that because:
1. The phone stays registered with CUCM1, which can be verified on the phone and via CUCM web interface;
2. Traffic passing through ASA is captured with ASDM packet capture.
That  should be it! I tried again this morning with the Branch ASA and after clearing the connections nothing passes through the appliance. Thanks a lot.
Good tip @GRANT3779
When changing ACL, "clear conn" (or at least clear conn for the specific host(s) affected).
When changing NAT rules, "clear xlate".
