How to clear pix 501 Max conn counter
shaun barrs
Hi All,
Does anyone know of a command to clear the maximum conn counter on a Pix 501.  Have had a look around the internet but can't seem to find a command that clears it?
Really don't want to have to do a reboot!
Shaun
Are you looking to clear the counter or the actual connections?  There is no command to clear the counter as this will fluctuate with the actual number of connection.  Clear conn will clear the connections.
Please remember to select a correct answer and rate helpful posts
Hi Marius,
It is to clear the most used counter only.  The only way I can see to clear this at the momment is to do a reboot, which we do not want to do.
FW# sh conn count
2812 in use, 11274 most used
Ah ok.  sorry misunderstood.
use the following command to clear the most used
clear resource usage resource conn
