03-10-2021 11:39 AM
I'm setting up a FPR1140 FTD 6.7, which is managed with on box Firepower Device Manager, for BGP routing. However I can't seem to find a way to configure "soft neighbor reset". The classic soft-reconfiguration inbound command does not seem to be supported. I really need the Firewall to update its BGP routes dynamically without me having to manually soft or hard reset the BGP neighbor ship. At least I can't find anything on the matter in the config guide. Also tried adding the command with flexconfig but I found that BGP commands are blocked in flexconfig.
Hopefully someone can hint me in the right direction.
Solved! Go to Solution.
03-11-2021 04:47 AM
Unfortunately this is not supported with FDM as of the current 6.7 release. We rely on the BGP neighbors to support route refresh or else we must perform a manual reset.
If this does not meet your requirements then you can use FMC management for a more full feature set.
03-11-2021 04:47 AM
03-11-2021 05:04 AM
Hi Marvin
Yeah I thought so. My BGP peer is an Azure gateway so I can't really do much there. But at least some clarity. Looking forward to 6.8 then
Thanks!
03-11-2021 10:10 AM
The successor to FTD 6.7 will be 7.0. FWIW I don't see the option there either.
01-10-2023 12:14 PM - edited 01-10-2023 12:15 PM
Hello Marvin,
I am trying to see how to enable bgp soft-reconfiguration on an FTD firewall managed in FMC. I don't see any options to configure it, and the FMC Help doesn't show it either.
When I connect to the FTD firewall via CLI, and issue the command to view routes being received by a neighbor, I get:
> show bgp neighbors 2##.2##.7#.3 received-routes
% Inbound soft reconfiguration not enabled on 2##.2##.7#.3
Thoughts? FTD and FMC are both running 7.0.4
01-19-2023 01:30 AM
Hello, My FMC is in V 7.3.0-69 My FTD 1150 is in V 7.0.4-55 and I have the same issue :
Do you know if there is a Know bug ?
> show bgp neighbors 10.132.7.254 received-routes
% Inbound soft reconfiguration not enabled on 10.132.7.254
01-19-2023 05:32 AM
I believe you can only configure graceful restart, not soft-reconfiguration.
https://networkingwithfish.com/bgp-graceful-restart-on-the-cisco-ftd-part-1-configuring/
01-19-2023 02:16 AM
I search everywhere and do not see where checked the feature on the FMC ... Something forget by Cisco team ?
