PIX VLAN Problem?
rryan
Community Member
I'm wondering if someone could clarify a possible vlan issue with a PIX515. I currently have a server/software firewall in place and am trying to replace it with a PIX515. My network has 2 user vlan's and a third for the router. My current firewall doesn't have any vlan configuration, it just passes all traffic to the router and then it sends it to the vlan. I can't seem to get the pix to pass traffic back inside. Must I configure vlan on the PIX? Thanks,
bparish
Community Member
yes, better to configure pix for listening these two vlans. dont pass the traffic to the router.
you will have two interfaces, one for outside
one for inside (vlan1 +vlan2)
thanks
rryan
Community Member
I'm trying to keep everything the same as it is. Do I have to do anything special on the PIX to pass data to and from the router. My inside networks are vlan1 and vlan2 at the switch level and my router is on 1,2 and vlan3which is for outbound traffic. It's a router on a stick configuration.
You will have to configure an 802.1q trunk link on the switch port that connects to your PIX. (interface fa0/1, switchport trunk encap dot1q, swi mode trunk). Than do something like the below on your PIX (changing the VLAN numbers to correspond to your VLAN's that you created on your switch). The PIX will route between VLAN's so you will probably be changing your routers config around as well. Be sure your PIX is running a minimum of PIX code 6.3 to do VLAN's. If your running 7.0, let me know, the config has changed quite a bit. The below config will only create the VLAN interface and the PIX will treat it as a completely seperate physical interface so you will need to create your routes, NAT, statics, and rules to allow traffic to pass.
interface ethernet0 auto shutdown
interface ethernet1 auto shutdown
interface ethernet1 vlan2 physical
interface ethernet1 vlan3 logical
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif vlan3 SomeName security50
nat (inside) 0 0.0.0.0 0.0.0.0 0 0 <--- or whatever
nat (SomeName) 0 0.0.0.0 0.0.0.0 0 0 <--- or whatever
ip address outside X.X.X.X 255.255.255.0
ip address inside X.X.X.X 255.255.255.0
ip address SomeName X.X.X.X 255.255.255.0
(etc....)
Hi baileja ,
How can a failover pix be included in this senario? single L2 switch provide 2 trunks to two PIX?
how to do that, pls advise.
