PixFirewall Problems.
fvelasco_rojas
Community Member
Hi. In my office I have a Pix Firewall 525. That equipment had the 6.3 software version and it was updated to 7.2(4) and now I have a problem: When I try to do a Videoconference with a Polycom Camera, is no possible to connect. I've checked the protocols and I see that with this version, the PixFirewall doesn't manage the "fixup" command for use the h323 protocol. this was changed for a MPF command, because when in the pix I wrote "fixup protocol h323" I recieve an answer "INFO: converting 'fixup protocol h323' to MPF commands". Somebady can tell me how can I do to activate this service again? I think that for this reason I can't use the Videoconferece System. Thanks a lot.
pstebner10
Level 5
Level 5
Check the last part of your config. You should have several entries under a heading titled "policy-map global_policy" that looks something like this:
class inspection_default
inspect dns migrated_dns_map_1
inspect ftp
inspect h323
inspect h323 h225
inspect h323 ras
inspect http
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
inspect pptp
inspect snmp
service-policy global_policy global
If the 'inspect h323' line is not in there, that is where you would add it instead of doing a 'fixup'
HTH,
Paul
Hi Paul and I apreciate your help, but it was the first instruction I checked, and that instruction is ok. I don't now if is necesary all the protocols that you say me, because my pix only has the following: policy-map global_policy class inspection_default inspect ftp inspect h323 h225 inspect h323 ras inspect http inspect netbios inspect ptp inspect rsh inspect rtsp inspect skinny inspect esmtp inspect sqlnet inspect sunrpc inspect tftp inspect sip inspect xdmcp inspect dns preset_dns_map --- Thanks a lot.
I once setup Polycom and I had to add the followings:
1. Create an object group for the ports used by polycom
object-group service VIDEO tcp-udp
port-object range 3230 3235
port-object eq 1720
port-object eq 3603
port-object eq 389
port-object range 1718 1719
port-object range 3235 3258
2. Create an acl to allow video traffic
access-list from-Internet-In extended permit object-group TCP_UDP any host 208.x.x.x bject-group VIDEO
Hope this helps.
duncanm
Level 2
Level 2
I gotta ask, what does the PIX say? You either have a ACL drop or a policy drop. The PIX will log both.
Have you run packet tracer?
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/p_72.html#wp1724426
