08-27-2007 11:00 AM - edited 03-11-2019 04:02 AM
has anyone had any problems with telnetting to an ASA 5550 firewall? I try to telnet but connection is refused, it does that for SSH connection as well. i am not sure if there is any other commands that need to be added to allow for inside interface. thanks
IOS version is 8.0(2)
telnet 11.27.18.11 255.255.255.255 INSIDE
telnet timeout 5
ssh 11.27.18.9 255.255.255.255 INSIDE
ssh timeout 5
management-access INSIDE
Ercan
08-27-2007 11:37 AM
For telnet it seems o be fine configuration... Please do one INSIDE interface shut and NO shut.
Also give telnet timeout 30 {It could possible 5 second problematic}
Second, For SSH connection : you also have to enable RSA KEY...
crypto key generate rsa module 1024
wr mem
ssh timeout 5
ssh ver 1 or 2
Dharmesh Purohit
08-28-2007 10:12 AM
hi,
thanks for the reply. it still does not work for telnet and ssh, but web access,ASDM works fine. Data traffic flows throught firewall fine inbound and outbound without any issue.
For ssh, now I am getting "ssh_exchange_identification: read: Connection reset by peer".
08-28-2007 04:23 AM
I had a similar issue.
When I investigated, turned out to be a routing issue. The Firewall could ping my machine, but my machine could not ping the firewall
John
08-28-2007 10:09 AM
hi,
my issue seems to be with the IOS version I am running, it could be a bug in the version 8.0(2)
08-28-2007 11:48 AM
from command line on the ASA can you ping the host that you are Telnet/ssh from and vice versa
08-28-2007 01:03 PM
hi
yes I am able to ping the host and vice versa
08-28-2007 01:00 PM
Are you coming over a vpn connection? I am asking this because you put in the command "management-access inside".
Here are some steps that I would suggest you to try:
-- try rebooting the ASA
-- connect a host directly to the ASA's inside interface and then try
-- try telnet 0 0 inside / ssh 0 0 inside
-- if nothing works, collect syslogs as you telnet/ssh to ASA and provide syslogs here.
I hope that helps..
