ā12-18-2022 12:36 AM
Hi All
What will be the Throughput speed of NGFW 4110 with Advance malware protection + Firewall Threat Protection (IPS) Install on the Appliance
What will be the Throughput speed of NGFW 4110 with Firewall Threat Protection (IPS) Install on the Appliance
ā12-18-2022 02:10 AM
Look at the below stats :
ā12-18-2022 02:17 AM
Dear Balaji
I have NGFW 4110 with Firewall Threat Protection (IPS) Install on the Appliance Now I want to Add Advance malware protection Service to the same appliance, I want to know what will be the Throughput speed of the appliance with IPS + Malware Install on the appliance
ā12-18-2022 02:34 AM
have you got chance to read the document posted on the above ?
ā12-18-2022 02:47 AM
Dear Balaji
Yes I have Read the Document
I need to Add Malware service to my Appliance will it degrade my Firewall Performance, and what will be the throughput speed of the firewall if i enable the malware services.
ā12-18-2022 02:51 AM
@sarfarazalisayed contact your Cisco partner, tell them your internet/WAN bandwidth and which features will be enabled, they can run this through the performance estimator tool and will tell you the expected performance.
This performance estimator tool is accessible only by partners and Cisco only, so it's not something you can do yourself.
ā12-18-2022 02:53 AM
YES / NO for your question - That is depends what is your current usage of the device, what will be impact when you add more service to kit is required some understand of your network usase and after adding new feature what will be outcome and degrade of kit will be observed,
So suggest to contact Local partner who can guide you and suggest to best.
